Need muffler with 37mm bolt spacing
Old 11-24-2010 | 03:56 PM
Default Need muffler with 37mm bolt spacing
It is for a 65cc Echo conversion. I can not find any good refrences on the net for such a spacing. Most just say it is for this or that engine without giving any dimensions. The link give in response to my other post on this issue was for little engines.
If somone has a pile of engines handy could you measure some and see if any "real" engines have that spacing. I can not justify spending a hundred bucks to get one made. There are some vendors that have ready made units for less than half of that figure. I just need to know the cross reference.
The mufflers I have made are heavy and always shake loose.
Old 11-24-2010 | 06:57 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Need muffler with 37mm bolt spacing
The Sachs/Dolmer 4.2 has a rectangular port and 38mm spacing
The DA 60 has a round port and 38mm spacing
http://www.rcextremepower.net/mufflers.html
A slight adjustment of the holes and they may work?
$40-$45
Old 11-25-2010 | 01:33 AM
Many thanks,
Scot
