Carbs.
MO
I bought a bunch of Walboro and Zima carbs off ebay and some look pretty good. How can I determine the model number or venturi size? Also a few only have one needle adjuster. Are they any good for glow/gas conversion?
My Feedback: (16)
You can look the Walbro carbs up here . . . .
http://wem.walbro.com/walbro/family.asp
You are on your own with the Zama's
http://www.zamacarb.com/prod_lookup.cfm
CA
The little number in the barrel of the carb is 64th of an inch. Figure that out in decimals of an inch and convert to metric to get the size in millimeters. I never understood why the just did not put 13.49, 15, 16.6 or whatever, in millimeters in the first place.
For instance, I am holding a WT542, the choke side has a little "34" inside. 34/64= .53 .53 x 2.54 = 1.34 so 13.4 mm.
ORIGINAL: Scota4570
For instance, I am holding a WT542, the choke side has a little ''34'' inside. 34/64= .53 .53 x 2.54 = 1.34 so 13.4 mm.
We were working in the English sytem of measurements until we went to the metric system, or did we? When was the last time you saw road signs with the speed limit in KpH?
Sincerely, Richard
