Homelite Rings
My Feedback: (51)
I ordered a set of new rings for the green 30cc Homelite I'm building and when they came they were the thin(.024) ones and not the .058 ones I wanted.The product number for the rings is 03179,but evidently these come in thin and thick ones with the same product number.Anyone have an extra set or know where I can get the right ones.A couple of places I contacted wouldn't take the time to measure the thickness, to make sure they have the right ones.
My Feedback: (13)
OR
skip stock and go for the best, contact Frank Bowman at [email protected] and he'll get you fixed up...
You can probably find Homelite rings, and for a few bucks less than from Frank Bowman. But Frank's rings are the best and will break in almost immediately and also give you noticeably more power, easier starting, etc. I don't use anything BUT Frank's rings in my engines any more.
If yours is a Homelite 25cc, the mod he does is to pin the ring which allows you to remove the exhaust port bridge which adds a lot of power to the 25cc Homelite.
AV8TOR
AV8TOR
My Feedback: (51)
My green Homelite is a 30cc and the piston has an offset pin with 1/2 of it is in the upper skirt above the ring groove and the other 1/2 is in the ring groove.I may yet try a set of his rings.He sent me a list of all the engines he makes rings for.
Frank Bowman
1211 N Allen Ave.
Farmington, N.M. 87401-3568
505-327-0696
Email: [email protected]
Reproduction Model Engine Rings
Quality at a fair honest price. Making a good ring is a Skill. Making a fine ring is an Art!
Last Revised 5 - 31 -11
I will reproduce nearly any model engine ring. If not available, I’ll need a good piston and cylinder to measure, or send motor. Send return postage, insurance is extra. For orders outside of USA, ask for shipping costs? Priority postage is extra. An order of 10 rings or more, discount of $1.00 off per ring, mixed orders are fine! Ring cost & shipping charges for USA listed below.
Please Note:
If you send me an engine for new rings that I don't currently make there will be No labor charge to do this.
If you send me the stripped down engine block ( Block, piston liner and rod assy.) for rings, that I Do currently make No extra charge.
If you send me a complete engine to disassemble, clean, and install the ring(s) and reassemble there will be a minimum charge of $25.00 per hour. My buisness is making Piston Rings and $25.00 is the minimum amount I would be losing by not making rings and working on your engine insted.
ATTENTION : NEW MEXICO CUSTOMERS WE HAVE TO CHARGE YOU 7.125% TAX, please add the extra tax to your orders.
Standard ring up to .65 engines: $9.00 ea.(1) shipped $13.00, (2) shipped $22.00 (1) .64 (2) $1.28
Standard ring from .66 & up: $10.00 ea.(1) shipped $14.00,(2) shipped $24.00 (1) .71 (2) $1.43
Dykes ring up to .65 engine: $10.00 ea.(1) shipped $14.00,(2) shipped $24.00 (1) .71 (2) $1.43
Dykes ring from .66 & up: $11.00 ea.(1) shipped $15.00,(2) shipped $26.00 (1) .78 (2) $1.57
** I also make special rings to order, ask for prices.**
Ace Twin .64
Aero .35
Aerrow 100 (pin) Quadra
Aerrow 200 (pin) Quadra
Aerovat 65 CC (pin)
Aircom M61 (pin)
Air-O .45
Anderson Spitfire .65
Area 51CC (pin)
Asp .52 4C, .61 (pin), .65 4/C, .80 4/C, .91 4/C
Atomic 60 Don Sohr
Atwood .49, .51, .63
Avion Mercury 1.609
Avistar .60 (pin)
Bantam .16
Bat .19
Bennelli 65 CC (pin) motorcycle
Berilli 36 CC (Pin)
BME 3.5 Twin (pin), 105 (pin), 110 twin (pin)
Brillelli 60 CC (pin)
Brison 2.4 (pin), 3.2 (pin)
Brown Jr. .60 cylinder sizes vary (send Piston & cylinder for proper fit & correct ring)
Brownie .29
Bushwacker 37.7 CC (pin) Sears
Bunch .45, .49
Cameron .15, .19
Cave Cobra
Chung Yang 29CC (pin)
Cleveland Tom Thumb .45
Comer 50CC (pin)
Como .29 (pin), .40 (pin), .51 (pin), .90 (pin)
Contestor D.60
CRRC Pro 26CC (pin), 40 CC (pin), 45 CC (pin), GF 50 i (pin)
CS .53 (pin)
Cub Cadet 25CC (pin)
DA 50 CC (pin) (2) different 1.678 Bore, & 1.681 Bore
DL 50 CC (pin)
DLE 20 CC (pin), 30 CC (pin), 55 CC (pin),110 Twin (pin), 170 Twin (pin), 222 4 cylinder (pin)
DME 100 Twin (pin)
Dooling .29, .61, Yellow Jacket
DZY 48 CC Twin (Pin)
Echo 16CC (pin), 21CC (pin), 21.2 CC (pin), 24.4 CC (pin), 30 CC (pin), CS-3000 (pin), 50 CC (pin)
Edco Sky Devil .64 Old or New (RJL) state which one?
Elf Andrea Heine Repo
Enya 3.5 (pin), .30 SS (pin), .35 X (pin), .40 X Dykes (pin), .40 Dykes model 6002, .40 4/C, .45, .45SS (pin), .46 4/C,.49 X (pin), 50SS (pin),.53 4/C, .60 4/C, .60 X (pin), .60 standard, .61 CXLR (pin), .80 X (pin), .80 4/C, .90 4/C, 120 4/C, 120 R 4/C, 1.55 4/C, 240 4/C Twin
ETA .29
EVO 150 Twin (pin)
EVRA 190
Forster .29, .31, .88, .99
Fox 36 Sand Cast (pin), .40 Sch., .45, .50, .59 .047 thick ring and .030, .59 long shaft Ign., .60 Blue Head, .60 Eagle, Eagle II .60 (pin), Hawk
Red Head .60 (pin), .74, .78, 120 Twin (pin), Gas Bore 1.439 ? (pin)
Fuji 43 CC EI (pin)
GMS .61 (pin), .61 Dykes (pin), .76 Dykes (pin), 1.20 Dykes (pin)
Hassad Blue Streak .64
HB .21 Dykes,.25 Dykes, .40 PDP Dykes, .40 Black Head (pin), .50 Dykes, .61 (pin), .61 Dykes
Hiller (Car)
Hirobo 36 (pin)
Homelite 25 CC, 30 CC (pin) old .060 thick pin centered (press in ) , 30 CC newer .030 thick (pin), 30 CC new style Off set pin, 33 CC (pin), 38 CC (pin), 40.6 CC Super EZ Chain Saw, Super Mini Chainsaw Dykes (pin), 45 (pin), 50 CC (pin)
Horner 3.7 Twin (pin)
Hornet .19, .60
Howler .60 (pin)
HP .21 4/C Dykes ,.40 (pin) ,.61 R.I. Silver Star (pin), .61 Dykes (pin) Blk Case Gold Hd.
Hurluman 60
Husqvarna 2100 (pin) Chainsaw Pin needs pressed in 1/2 way
Irvine .20 Dykes, .25 Dykes, .36, .40 Pylon Dykes (pin), .40 Standard (pin), .46 MKII Q46 Dykes, .61 Dykes, 120 Dykes, 150 standard non pin.
JC Evo 28 CC (pin)
Kavan MK 50
Kaw T5A 60 CC (pin) Artic cat Snowmobile
KDC Kioritz 21.2 CC (pin), 23.6, 25 CC (pin), 30 CC (pin), 58 CC (pin)
K&B .35 Dykes, .40 Dykes, .40 S Dykes (pin), .61, .61 Dykes (Lee Custom), 1.35 (pin), 1.5 (pin)
Kometa 29
Kraft .61 (pin)
Kratmo 10 CC, 4A Ignition
Laser 61 4/C
Lewis 60
Magnum .52 RFS 4/C, .53 XL 4/C, .61 XL (pin), .61 4/C, 70 4/C, .91 XL 4C, 120 4/C, 120 (pin)
Maloney 100 (pin), 125 (pin)
McCoy .09, .19, .19 Dykes B.H., .21 Dykes Car, .29 all versions, .29 Dykes B.H., .35 Dykes B.H., .36, .40 Dykes B.H., .49, .55, .60, .60 Dykes
McCulloch 15 CC ? (pin) 1.024 Bore, 21 CC (pin), 25 CC (pin) MDB 90 Leaf Blower, 28 CC, 32 CC (pin),
MDL 28 CC (pin)
MDS .78 (pin), 1.48 (pin), 2.18 (pin)
Merco .40, .49, .49 Dykes, .50, .61, .61 Dykes
Micron 60
Moki M .51 (pin), .61 (pin), 1.20 (pin), 1.35 (pin), 1.50 (pin), 1.80 (pin), 2.10 (pin)
MT 42CC (pin), 57 CC (pin)
MVVS .40 Dykes (pin)
O&R Industrial Motor 1 HP
OPS Maxi .30 (pin)
OS .20 FS 4C, .26 4C, .28 FH Dykes (pin), .30 fs 4/c, .32 (pin), .37 H (pin), .40 H Dykes, .40H Standard, .40 H (P) Pylon, .40 FS 4/C, .40 SF (pin), .807 bore, .40 SR (pin), .40 FSR .835 Bore (pin), .40SR Dykes (pin), .45 FSR (pin), .45 FSR Dykes (pin),.45 RSR Dykes, .46FX (pin), .46SF (pin), .46 4/C, .48 4/C Surpass, Max .50 old, .50 FSR Dykes (pin) ,.50 H (pin), .50 SX & SXH (pin), .52 4/C surpass, .58, Max-H .60, .60 FS 4/C, .60 FSR (pin) .9445 Bore ,.61 SF .9055 Bore (pin), .61 FS 4/C, .61 SX (pin), .61 SXH (pin), .65 RSR (pin), .70 4/C, .75 4/C Surpass, .80 H,.80 Dykes (pin), FS.90 4/C, .91Surpass 4C, .90 FSR (pin), .91 FSR (pin), .91 FX (pin), .91 SX H (pin), 1.08 BX-1 (pin), 120 4/C, 120 twin 4/C, 120 AX (pin), 160 FX (pin), 160 4/C, BGX-1 3500 (pin)
Poulan 25CC (pin), 25 CC Featherlite (pin), 32CC (pin), 35 CC (pin), 42 CC (pin), 42 CC Wildthing (pin), 46 CC (pin), 54 CC (pin), 60 CC (pin)
Pioneer Grass Trimmer Model B 440, 42 CC (pin)
Profi .40 (pin), .61 (pin), .76 (pin)
Quadra 35 CC , 40 CC (pin), 42 CC (pin), 50 CC (pin), 100CC Aerrow (pin), 150 Twin (pin) , 200 CC Aerrow Twin (pin)
Quick Draw CC (pin)
RCGF 20 CC (pin), 32 CC (pin), 45 CC (pin)
RCS 1.40 (pin)
Ross .60 Dykes (pin), .60 opposed twin Dykes (pin), .61 (pin)
Rossi Speed .60 old, .60 (pin) .021, .61 (pin) .023, .65 (pin) .0235, Speed .65 (pin)
Royal 40 (pin)
Ryobi 26 mm Bore EJ 100 (pin), 31CC (pin) older .064 thick, 31 CC (pin) newer .047 thick
Saito FA .30 4/C, .40 4/C, FA .45 4/C, FA .50 4/C, FA .56 4/C, FA .60 Twin 4/C , FA .62 4/C, FA .65 4/C, 72 4/C, FA .80 4/C, FA 82 4/C, .90 4/C, .91 4/C, 100 4/C, 120 4/C, FA125 Golden Knight 4/C, FG 20 125 4/C, 130 TD 4/C Twin, 150 4/C, 180 4/C, 270 4/C Twin, 300 4/C Twin
Sachs 2.0 (pin), 3.2 (pin) offset, 3.2 (pin) centered, 5.8 (pin)
Sap-180 HP 1.2 (pin)
Scott Thunderbird
Sears Weedeater, Bushwacker,18 CC, 21 CC, 25 CC, 25 CC TWC Leaf Blower, 37.7, all pinned, 1966 Allstate Moter Cycle engine made by Puch (pin)
Shindiawa 33 CC (pin)
SIFK 29CC (pin) AKA CY, Chun Yang
Skil chainsaw (pin)
Sky Chief .53
Solo 2/C tiller approx. 20CC (pin)
Spe 25.4 (pin), 26 CC (pin), 40CC (pin), 45CC (pin)
Stihl 25.4 (pin), 028 Chain Saw 44 CC (pin), Super 45 (pin), 57 CC (pin), MS 440 Chainsaw 70 CC (pin)
Super Tigre G20.15, G20 .19, G20 X.25, S .29 (pin), G21.29 old, .34 (pin), .40 Bullring, S.40 (pin), G21.40 std., G21 .40 Dykes, G21.46 std. ,S.45 (pin), V.45, X.45 (Pin), G21 .46 wide Dykes, G.46, G .46 Bullring, V 51, G51 (pin) Italian, G51 (pin) China, V.56, V.56 Dykes, V 60 light case .044 or .047 top to bottom measurement, G24 60 Old, G 60 Bluehead, X60 (pin), V.60 wide & narrow Dykes, S.61
(pin), G.71, S.75 (pin) Italian, S.75 China, G.90 (pin) Italian, G.90 (pin) China, 2000 (pin), 2300 (pin), 2500 (pin), 3000 (pin) Italian, 3000 (pin) China, 3250 (pin) Italian, 3250 (pin) China, 4500 (pin)
SV 50 CC (pin)
Syncro B-30, Syncro ACE, Syncro ACE Special
Tartan 1.34 (pin), Twin .77 (pin)
Tech 23CC (pin)
Technipower 7 Cylinder radial, B series, 9 cylinder
3MM 53 TOC (pin)
3W 26 CC (pin), 80 CC Boxer Twin (pin)
Thunder Tiger .39 (pin), Pro .50 H (pin), .53 Red Line Heli (pin), .54 4C, .91 FS 4C, 120 Pro (pin)
Toki .40 (pin)
Ueda .45, .61
US 25 CC (pin)
Vlvatam 2.5, 5 CC
Veco .21 Dykes, .50 Dykes, .61, .61 Dykes
Vega 10CC, 91 4/C
Webra .32 Speed Dykes (pin), 35 (pin), 10 ccm, 6.5 (pin), .40, .40 (pin), .40 Dykes (pin), .50 Dykes (pin), 52 (pin), .55C AAR Red Head Heli (pin), .61, .61 (pin), Speed .61 FS (pin), Speed .61 F Dykes (pin), .61 Dykes (pin), Speed 70 (pin), T480 4C Dykes, .91 (pin), 91 PS (pin), 120 Dykes (pin), 1.2 LS (pin), 91 (pin) T 4.90, 35 CC? Bully (pin)
Weedeater 18 CC (pin), 21CC (pin), 25CC (pin) 1.358 Bore, 25CC (pin) 1.380 Bore, 28 CC (pin), 32CC (pin)
Weedwacker 25CC (pin)
Westbury Atom III
Yamaha 50CC (pin)
YS .50 ST,.61 Long Stroke (pin), .63 4/C, .80 H (pin) 2C, F.91 AC 4C, .91 2C (pin), 110 4/C, F120 4C
YW 24CC single & 48CC Twin (pin)
ZDZ 40 (pin), 50 NG RV (pin), 60 RV (pin), early 80 RV (pin), later 80 - J model (pin)
ZEN G270 (pin) AKA Chung Yang
Zenoah G20 (Pin), G23 (pin), G26 (pin), G38 (pin), G45 (pin), G62 (pin), GT-80 Twin (pin)
Frank Bowman
1211 N Allen Ave.
505-327-0696
Please Note:
Ace Twin .64
Aero .35
Aerovat 65 CC (pin)
Aircom M61 (pin)
Air-O .45
Area 51CC (pin)
Atomic 60 Don Sohr
Avion Mercury 1.609
Avistar .60 (pin)
Bantam .16
Bat .19
Berilli 36 CC (Pin)
Brownie .29
Bunch .45, .49
Cameron .15, .19
Cave Cobra
Comer 50CC (pin)
Contestor D.60
CS .53 (pin)
DL 50 CC (pin)
DME 100 Twin (pin)
ETA .29
EVO 150 Twin (pin)
EVRA 190
Fuji 43 CC EI (pin)
Hiller (Car)
Hirobo 36 (pin)
Hornet .19, .60
Howler .60 (pin)
Hurluman 60
JC Evo 28 CC (pin)
Kavan MK 50
Kometa 29
Kraft .61 (pin)
Laser 61 4/C
Lewis 60
MDL 28 CC (pin)
Micron 60
OPS Maxi .30 (pin)
Quick Draw CC (pin)
RCS 1.40 (pin)
Royal 40 (pin)
Scott Thunderbird
Skil chainsaw (pin)
Sky Chief .53
SV 50 CC (pin)
Tech 23CC (pin)
3MM 53 TOC (pin)
Toki .40 (pin)
Ueda .45, .61
US 25 CC (pin)
Vlvatam 2.5, 5 CC
Vega 10CC, 91 4/C
Westbury Atom III
Yamaha 50CC (pin)
If the original second land ring is any good at all, I usually just put a Bowman ring on the top groove, and run the stocker in the second groove. It's really not necessary to run two Bowman rings.
You could even leave the second ring out. You get slightly more high rpm power with only one ring, but I like to use two for a little extra sealing security and to stabilize the piston for longer ring and possibly piston life.
AV8TOR
AV8TOR
