Poulan Pro PP033
Old 12-21-2011 | 05:08 PM
CTSmithey's Avatar
Default Poulan Pro PP033
I have a buddy that sells refurb's of these Poulan Pro PP033 he has 9 of them at the moment and is offering them to me at 50$ each. Here is a link to Poulan on them www.poulanpro.com/node7967.aspx has anyone seen, or done a conversion on these? I have looked at the motor schematics and see that they are a full shaft motor (Good Thing!) If anyone has any info on converting these weither Yea or Nea I would like some opinions and advice if any. Here are some base specs for the motor.
Thank you for taking time to read and reply. Any and all advice is welcome.
CTSmithey
<table cellspacing="0" cellpadding="0" border="0" class="techdataTable"> <tbody> <tr> <th colspan="2" class="techdataGroup">Engine</th> </tr> <tr class="techdataRow"> <td class="techdataName">Engine type</td> <td class="techdataValue">33cc 2-Cycle Gas</td> </tr> <tr> <th colspan="2" class="techdataGroup">Cylinder and piston data</th> </tr> <tr class="techdataRow"> <td class="techdataName">Cylinder displacement</td> <td class="techdataValue">33 cc</td> </tr> <tr> <th colspan="2" class="techdataGroup">Equipment</th> </tr> <tr class="techdataRow"> <td class="techdataName">Handle type</td> <td class="techdataValue">Loop</td> </tr> <tr class="techdataRowAlt"> <td class="techdataName">Type of shaft</td> <td class="techdataValue">Bent/Split</td> </tr> <tr> <th colspan="2" class="techdataGroup">Cutting equipment</th> </tr> <tr class="techdataRowAlt"> <td class="techdataName">Cut Path</td> <td class="techdataValue">17 "</td> </tr> <tr class="techdataRow"> <td class="techdataName">Type of trimmer head</td> <td class="techdataValue">Tap 'N Go Dual Exit Head</td> </tr> <tr> <th colspan="2" class="techdataGroup">Overall dimensions</th> </tr> <tr class="techdataRow"> <td class="techdataName">Weight incl. packaging</td> <td class="techdataValue">18.6 lbs</td> </tr> </tbody></table><table width="100%" cellspacing="0" cellpadding="0" border="0" class="articles"> <tbody> <tr class="rowAlt"> <th width="86" class="artnocol">Part Number</th> <th>Description</th> </tr> <tr class="row"> <td>952711961</td> <td>PP033 Gas Trimmer</td> </tr> </tbody></table>
