ECHO CS-360 Short Block
My Feedback: (45)
LA
I got a pretty decent deal on a CS-360 short block with the factory magneto. Does anyone know where I can get a prop adapter from? I was thinking an adapter I could use with the stock flywheel. Or if I have to I'll convert to CD ignition.
CA
Not specifically.
You will need to determine the thread size and pitch on the part of the crank that the flywheel retaining nut is threaded onto. If you get real lucky it will be like a Ryobi short shaft.
http://wackerengines.com/Ryobi.htm
http://indianatinygasengines.com/page008.aspx
There was another outfit that did echo SB-1080 (50cc) hubs but I cant find them right now.
