Carb dripping fuel when inverted - help
Old 11-26-2012 | 06:00 AM
Default Carb dripping fuel when inverted - help
Hello everyone
I am having trouble because when I take off my Toro 26cc seems to be well carburated, but when I take off it goes way to rich.
Yesterday I noticed as well that when I invert the plane (cilinder pointing to the ground) and therefore tank is higher than the carb theres some gas dripping.
Could this be that the carb membrane is not OK....I check it and it seems stiff
Would it help to leave it 24 hours soaked in gasoline to have it less stiff?
Thanks for any help
Victor (Oddy)
Old 11-26-2012 | 08:41 AM
av8tor1977's Avatar
Default RE: Carb dripping fuel when inverted - help
When a carburetor leaks, it is usually caused by a bad diaphragm. They get stiff and don't work. They must be very flexible. The engine is probably flooding and the fuel only comes out when you invert it. (I remember that your plane has the cylinder in the upright position.) Check all your fuel line connections but I am betting your problem is the diaphragm. I have tried and tried but never found a way to make them flexible again once they have dried out and gotten stiff. Nothing you soak them in works.
As far as the engine only going rich when you fly it, that could be caused by air pressure in flight hitting the hole in the cover over the diaphragm. The cure for that is to solder a tube into that hole, and then run a hose from there into the fuselage so it doesn't get hit with ram air from flying. If you solder a tube into that hole, make sure the side that goes towards the diaphragm is smooth so that it doesn't restrict or damage the diaphragm.
AV8TOR
