Cheap electronic ignition?
Old 11-08-2013 | 01:48 PM
Default Cheap electronic ignition?
I'm in the process of converting a 21cc Weedeater engine (among others). *I'd like to try using an*electronic*ignition on this one. *Who has the cheapest electronic ignition module for this engine? *I've checked online and an Rxcell costs 70.00. *I can get a module for a Zenoah G-20 for 58.00. Any other website have one for less?
Jeff
Old 11-08-2013 | 02:22 PM
Tidnab's Avatar
My Feedback: (51)
Maybe this would work.Certainly is cheaper.Be sure to pick the US Warehouse at the top. http://www.hobbyking.com/hobbyking/s...earch=ignition
Old 11-11-2013 | 08:28 PM
av8tor1977's Avatar
I've used those Hobby King ignitions. Out of 6 that I purchased, one was bad and had to be returned. Takes a long time for them to process customer service.
Try here for a really good ignition for only slightly more: www.rcextremepower.net/ignitions.html
AV8TOR
Old 11-17-2013 | 12:01 PM
Buy from RCextreme power. It is only 13 bucks extra. You can work with them in case of a problem. Shipping from china will be a long wait and wil be expensive. If you have a problem forget about service of help from hobby king. They have their place. I accept that some of the stuff will be junk when I buy from them. A bad ignition will be very frustrating and not worth the 13-bucks saved. There is a possible safety risk. An erattic igniton could cause a kick back. You definately don't want to get you finger wacked. I did that a while back with a baulky engine. It caused perminent nerve damage.
Old 12-26-2013 | 05:30 PM
Hi Jeff.
If you don't mind a used or a repaired and tested ignition, I have dozens sitting idle for a cheap price.
Email me at:
[email protected]
i can probably help you out with a good unit for the Echo.
John
