Ryobi 31
Howdy
I just got a ryobi 31 weed trimmer in the mail. Am going to break it in on the yard then start the conversion. My question is: does anyone have the specs for the prop hub? I have access to a machine shop and aluminum. I would also appreciate ideas for homemade mufflers. Thank you so much!
Tommy
Tommy
KY
You can break it in on the trimmer if you want just try and get 1 to 2 Hrs. on it if you can.Vary speed some at first, I think you'll be pleased wth the Ryobi once it's broken in.As for prop shaft you'll need to know if your's is short or long shaft .[&:]
