Stihl 2.2
Old 11-11-2003 | 07:42 PM
Rotorwrench's Avatar
Default Stihl 2.2
A friend of mine at work gave me all of his old R/C planes and parts, including a Stihl 2.2 engine with electronic ignition. I have never worked with gas engines before and I know nothing about them.
Is this a good engine? All I need for it is a new muffler, but where can I get one? Also what is a good airplane to put this engine in? I prefer scale aircraft like AC7 Champs, Cessna 140s and Cubs.
Thanks in advance for any help anyone can give me. Rotorwrench
Old 11-11-2003 | 08:34 PM
My Feedback: (9)
Default RE: Stihl 2.2
I'm not sure about the exact displacement in CC's but I think it will be 36 or 37. That should be more than adequate to fly Cubs & Cessna's in the 80 to 100 inch range. Try a 20-8 prop to start and do some performance tests. Try to prop the engine so it will turn around 7000 -7500 rpm. That should give you plenty of thrust. Someone has likely already done one of these conversions, and can give more accurate info. Good luck.
Old 11-11-2003 | 08:46 PM
if you want a kit look at the dynaflite and balsa usa kits or something under 20 lbs if it is a non aerobatic.should swing a 20x8 prop AOK
Darin
