homie
My Feedback: (23)
I think you're asking for a "crankcase". Short block in 2-cycle engine terms usually means the entire engine assembly (crankcase, cyl, piston, conrod, crankshaft, bearings), with no plug, muffler, carb, or ignition parts hanging off it.
AL
Thanks guys I guess it makes more sense to just by a new engine being that it is so cheap. My problem is that I bought a 25cc homie from a local small engine shop, it was used and I only paid $10 for it. It turned out to be a dud it runs but the housing is cracked and leaking crank case pressure which is precious in a 2 stroke motor. I took it apart and the piston and cylinder and bearings looks real good so I wondered if I could just get another cylinder housing for it but I guess if it is going to run too much it would make sense to start over and use the rest for parts.
OR,
If you still want just the crank housing I can supply that for a small sum plus shipping. I have been selling weedy engines on eBay for some time now and have lots of usable spare pieces. (farley9n on eBay) or ([email protected]) Let me know.......Thanks...Bob
