Homie flywheel removal?
Old 12-08-2003 | 10:10 PM
Default Homie flywheel removal?
This is my first conversion and thought I better ask before I take the hammer to it. Its a 30 cc and looks to be almost new. Might try it on a GP Spacewalker.
Aloha, Les
Old 12-08-2003 | 10:17 PM
Default RE: Homie flywheel removal?
Loosen the flywheel nut until it is flush with the end of the shaft, stick a screwdriver under the flywheel and gently pry upwards and lightly tap the end of the shaft with a soft faced hammer. It should pop right off.
JimRoss
Old 12-08-2003 | 10:26 PM
Thanks Jim.!
Wow a few taps on the keyboard and my flywheel is off!!!
Amazing
Aloha Les
Old 12-09-2003 | 08:51 AM
No problem Sir,
Glad I could help. You just have to remember that you can't get too aggressive with the hammer or you will mushroom the shaft end. Then you have problems.
JimRoss
