looking for a source to get a new 28cc maculloch
My Feedback: (14)
NC
i have one of these conversions and i need a new motor, the motor that i have burned up and i want to buy a new one and use the conversion kit that i have. i did a search on google but i kept coming up with a leaf blower that had that engine. Do any of u guys know of a source were i can get a brand new one?
OR,
Hi Racer! There is a guy who sells these engines new for somewhere around $50. I think he has both the 28cc & 32cc versions. If all you need is a few good used pieces I can provide parts for most Mac's. I also sell engines but don't have anything going right now.....Bob (farley9n)
My Feedback: (14)
NC
to farleypn, i need the black spacer piece that goes in between the carb and the motor and possibly a piece for the piston, i'm not sure what the guy called it that i had him look at it but yeah what kinda parts do u have for the 28cc, maybe i'll remember
OR,
Hey Racer! I'm sure I have the spacer that goes between the carb and cylinder but I can only guess at the piston part you want. Is there any way you can send me a picture of the part? Also I will check to see if I have a good short block assembly for you. (That would be a crankcase, rod, piston,rings and cylinder.) I will have to go out to the barn and check.........Bob
OR,
Racer I found a very good 28cc cylinder with piston and ring. It also has the black carb spacer and a muffler on it. If you need another crankcase assembly I have that also........Bob
My Feedback: (14)
NC
yeah i definately need that spacer, how much u want for it, i talked to the guy today and he said that should be all i need, but if i need any other parts i'll let u know, but i definately need that spacer, thanks a bunch
OR,
Hey Racer! Did you get my address Ok? Let me know via email. I can also be reached using ([email protected]). I'm going to be away for a week starting Feb.24 and would like to get this part out to you before I leave......Bob
My Feedback: (30)
WI
I have a new power head with less than 1 hour run time, I wll let it go for $50.00 shipped.
email [email protected]
