RYOBI 31cc questions
Hi all, first time here, I have some questions about my ryobi 31cc engine, (weed trimer) that Im using for a deep vee hull project,
Ive read about the air plane conversions for jag engines, but I need some answers for my boat,
My factory carb should be replaced or hogged out, (zama P10a 64p) on carb, my carbs about 315."
Anybody got a suggestions about a good size and brand of carb, or should i enlarge this one.
Any body have experience with internal porting on these engines, looks like plenty of room to grind ports on this head
I think I will just run as is for now, unless mods are simple,
On carb, can i remove the venturie tube before enlarging this type of carb, (tube is the one that looks like the tip of a empty 22 case with a little grill in it, can i back it out?pop it out? only looks bonded in.
thanks for your answers, post all ryobi 31cc stuff for me please
Also: I do not want to have a upright canister muffler on this boat motor, I want to rout watercooled exhaust out the the back, anybody here ever run this engine with tuned/custom exhaust, thought i could modify a zenoah or just fabricate my own, just need to know what works well on the 31cc ryobi (50"boat)
Pete at www.wackerengines.com has the carb you need for like $20. Dont take a drill to enlarge your current carb, you'll only damage the airflow and render it almost useless.
My Feedback: (23)
You can drill out the venturi, if you know what you're doing. I've gotten some that are done that way and they work just fine. Personally, I would let somebody else do it or just find a good deal on big bore carbs on E-bay - it's much easier.
