Finding a carburetor part.
Old 02-19-2004 | 07:09 PM
Default Finding a carburetor part.
I took off the spring that comes inside of a Walbro carb, to avoid tension to the servo, but now the barrel do not actuates correctly.
I actually have to replace a spring ( but don´t know how to separate the plastic parts to position a new spring) inside the barrel of the walbro carb. or order the entire part with spring already installed.
it seems to be the WYL K-20, "160A-218 pinted on, do you know were to get a exploded view of the carb and were to order the part or entire carb??
Old 02-20-2004 | 04:43 AM
Default RE: Finding a carburetor part.
Tato. Can you find any other carb to put in its place? It would seem to me to be cheaper to get a whole new carb than just a part or group of parts to repare that one. I did have one that came on a motor of mine. It had no way to adjust mixture so in the trash it went but I did look it over good and I think that all the parts your talking about were pressed on, you might get it apart but not back together.
Old 02-20-2004 | 09:46 AM
jstanton's Avatar
My Feedback: (14)
Tato
Here is a place on the web where you can look at all of the parts within your walbro carb. You find the part # than you have to order it from a distributor in you area. Here is the link http://wem.walbro.com/walbro/family.asp. Just pick the manufacture of your engine that you will have to look for your walbro carb #. Good Luck
Old 02-20-2004 | 10:11 AM
Mr.Pipercb
I´m afraid that your thougts are right , i seems that the pieces involved in the barrel and throttle system are sealed somehow.
Do you know were could I order a new one?? it is only the barrel complete assembly, with spring and the connection collar to the throttle flexiblerod.
We check the carb and in its bse the pressuere fitting is not in the middle of the two mountig holes for the bolts. it is displaced to one side, and all the carbs we saw at the servie store were with the pressure hole in the middle, symetrical.
Thanks for the imputs.
Old 02-20-2004 | 02:24 PM
ok..heres a guy on ebay that sells that carb for $15. His ID is 55chava. He's not selling any right now but that doesnt mean an email to him wont get you one. Piper
