Sthil conversion
Old 04-29-2004 | 11:26 AM
My Feedback: (13)
Default Sthil conversion
I have finally talked my brother into parting with his 045 Super Sthil chain saw. Does anyone market prophubs and carb adaptors to fit, or will I have to reinvent the wheel? I have 4 C&H ignitions, etc, and access to a machine shop at work but, again, why reinvent the wheel?
Thanks guys
Old 04-29-2004 | 01:36 PM
Antique's Avatar
Default RE: Sthil conversion
Re invention required
Old 04-29-2004 | 09:55 PM
It should not be to hard of a job. Someone could easy give you the data for the needed machine work. Seems like a helpfull RC er could do that. Good luck, Captin
Old 05-25-2004 | 01:32 PM
My Feedback: (13)
finally figured out the carb mounting- made an aluminum block to slide on the cylinder nipple and held in place with 2 set screws. The mount appears easy as well as the prop hub. When I removed the flywheel, it is a small finned aluminum ring with a metal plate under it that has a 3 bolt pattern. I can now make a prop hub similar to the ones used on Quadra engines and bolt it directly to the steel plate. In this way the original bolt stays in place to hold the flywheel assy on and I believe I can still use the original electronic ignition without havint to add the C&H after all.
As time permits, I will post a couple of photos since I saw several other threads concerning the carb mount.
