Poulan 42 cc conversion with magneto?
Old 12-30-2007 | 12:21 PM
av8tor1977's Avatar
Default RE: Poulan 42 cc conversion with magneto?
Sorry to say, but I really think you should spring for electronic ignition or go Gas/Glow. I felt my 42cc Poulan was rather heavy even on Gas/Glow. I'm afraid yours is going to be quite heavy and bulky.
The cost has come down on ignition systems. Check www.ch-ignitions.com
Good luck,
AV8TOR
Old 12-31-2007 | 12:49 PM
I would like to use the stock muffler. How do I take it apart and gut it? Do I need to drill outlet holes in the muffler for the exhaust and if so, how many and what size?
Old 12-31-2007 | 06:46 PM
Ralphbf's Avatar
My Feedback: (27)
If you are planning on using the same carb. I wouldn't modify it to much,
especially if you have a one needle carb. or limiters on it.
You will run out of adjustment in a hurry.
Being a chain saw the mufflers aren't all that bad.
A lot of mufflers have a screen over the outlet.
Try removing that and go from there.
Your muffler looks sealed and can't easly be opened and resealed.
Old 01-24-2008 | 10:28 AM
I finished up my 42cc conversion and was able to keep the magneto ignition by keeping just enough of the saw case to keep the coil in the proper position. I did a little more trimming to the case since I posted the photos. I’ve test run it twice on a test stand and it runs and sounds great. I have not tached it though. However, it is quite heavy as I did not trim the flywheel or do any of the typical things to loose weight. It has the 11.11mm carb and stock chainsaw muffler. I mounted it to the plane that used to have the flywheel/magneto Homelite 30cc and after adding 5 ounces of tailweight to get it to balance, it came out 2 pounds heavier than with the Homey. I still need to test run it and tach it on the airplane, and if satisfied, I’ll try flying it. However, I’m thinking that I may go with the gas/glow setup. How much weight could I feasibly loose by doing this? Is it possible to get it down to what the flywheel Homelite 30cc weighs? If so, I could remove the added 5 ounces of tail weight. I’m thinking that the portion of the saw case I kept weighs around 5 or 6 ounces also. Does anyone know how much the flywheel/coil/spark plug assembly weighs on a Poulan 42cc? Obviously, what I’m trying to do is replace the 30cc with the 42cc for more power and keep my flying weight the same or very close. I guess I need to order a glow plug adapter, an OS four stroke plug, and try to get some 10/10 glow fuel. I hate to buy a gallon of 10/10 since I have 4 unopened gallons of Omega 15% already, but if I have to, I will. Am I forgetting anything else?
Old 01-24-2008 | 12:44 PM
dogshome's Avatar
ORIGINAL: plasticmaster
If anyone has ideas or comments on my approach to this conversion, please let me know.
Well she's not going to win any beauty prize, but should work OK. I guess you noticed that quite a lot of support is needed to stop the coil being attracted to the magnets while it's running - so you can't hack too much away there.
Old 01-24-2008 | 01:12 PM
  #31
You're right, I did see movement in the coil mount as I rotated the magnets past, so I secured it with a steel zip tie around the coil mount and around the back side of the muffler. Now, there is no movement when I rotate the flywheel. I'll run it a bit on the ground to make sure everything is holding up OK before I fly it. Also, I don't think it would be that hard to replace the hacked up saw portion with an aluminum bracket to hold the coil. I think it could be made with small pieces of aluminum L channel to mount the coil in the exact position. I may still pursue this if I don't go the gas/glow route.
Old 01-24-2008 | 02:22 PM
  #32
dogshome's Avatar
The alloy channel route is how the coil is fitted to my McCulloch. Looks quite professional with the corners trimmed and small capheads holding it all together.
Old 01-24-2008 | 03:29 PM
  #33
Hi plasticmaster, if you can get some methanol try to mix one part methanol with 2 parts 15%nitro glow fuel this should give you a 10% nnitro mixture as for oil if its on a 18% oil content you'll probably end up in the 12% range so probably your mixture will be a 10/12 glow fuel which once you mix with 2 parts gasoline it will give you a 3.3% nitro and a 4% oil content, so go ahead and make a samll batch and try it on your 42 poulan as Gas/Glow mix with an OS 4F plug.
A 1 to1 mix of 15% glow fuel with methanol will give you a 7.5% nitro and 9% oil glow fuel that you can alsomix with 2 parts high octane gasoline and at the end you will have a 2.5% nitro and 3% oil which isn't bad for Gas/Glo fuel either.
Old 01-24-2008 | 09:40 PM
  #34
Ralphbf's Avatar
My Feedback: (27)
I'd mix up a batch of fuel using the 15% flow fuel.
Knowing that this isn't the ideal mix run it to see how is works.
Leave everything in place and give it a shot.
I did this on my first conversion and I knew I was on to something good.
It was a 32cc Mac that was discarded by another flyer when the EI went out.
It ran better on gas-glow than it ever did on EI.
Old 02-01-2008 | 07:11 AM
  #35
AV8TOR,
How much did your Big Stick weigh with the 42cc on gas/glow, ready to fly?
Old 02-01-2008 | 09:34 AM
  #36
Hey plasticmaster, regarding the stock muffler depending on how new it is it could have a catalyst. If you have "material" looking stuff inside, I would round up another muffler.
Old 02-01-2008 | 09:57 AM
  #37
I've only run the Poulan 42cc with the original muffler completely stock. I've taken it apart though and the exhaust goes into a hard metal "cage" with holes in it. This cage is also wrapped with the spark screen and the cage gives support when tightening the muffler to the engine. Once I get it running on gas/glow, I'll try running it again with the stock muffler and then with the spark screen removed. These are the only components inside the muffler shell.
