50cc? What saw and where to get one??
Old 08-27-2004 | 07:16 PM
My Feedback: (67)
Default 50cc? What saw and where to get one??
Hello I have had a poulan 46cc saw, but have heard they also make a 50cc. I would like to get a good 50cc engine running that is pretty light. Anyone know what Poulan saw number I should look for, and is there anyother brand other than echo that makes a good conversion 50cc engine? Thanks fellas!
Old 08-27-2004 | 10:42 PM
My Feedback: (27)
Default RE: 50cc? What saw and where to get one??
how about a husky 61 cc, not much bigger than the 50cc specified.
Old 08-29-2004 | 07:19 PM
My Feedback: (67)
Got any pics of one? What do they weigh? How hard are they to conert? Any help would be appreciated.
Old 08-29-2004 | 07:30 PM
ZAGNUT's Avatar
i may be wrong but i think the larger poulans have a two piece case and separate jug, not the nice, light jug with a bottom cap like the 46 or echo 50
dave
Old 08-29-2004 | 09:04 PM
w8ye's Avatar
My Feedback: (16)
That's correct. The 54 and 60cc Poulans have a big crankcase that includes the tanks. There's a lot of cutting. The case is held together with screws that are fore - aft oriented. So, a mounting plate has to be made. They make a nice engine but it's a lot of work. If you have the work done, there's a guy on here that does a nice job for around $250+ range. It's not cheap but this includes the electronic battery ignition conversion.
The 60cc was discontinued in the previous century. I don't know if the 54 is still around? It was last year. They pretty much had the same case. There were many different models of these. My 60cc is a 3750 type II but later types were 54's.
Enjoy,
Jim
Old 08-30-2004 | 12:14 AM
Antique's Avatar
60 cc Poulan
Old 08-30-2004 | 09:54 AM
Volfy's Avatar
My Feedback: (23)
The Echo 50cc chainsaw engine would be a good choice. A while back I saw quite a few of these offered on Ebay. Same engine as the BME 50 so you can probably get parts (prop hub, muffler, etc.) from BME. Then again, maybe not.
Old 08-30-2004 | 05:50 PM
ZAGNUT's Avatar
if looking for an echo 50 to convert and you want it to be like the BME then be sure it's the CS-510 model.
the older CS-500 and CS-5000 models have the case as part of the saw body and require lots of cutting and fabrication of a backplate mount.
dave
