Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
 best carb or mod for ryobi 31cc. need more power >
Old 10-28-2004 | 12:03 PM
Default best carb or mod for ryobi 31cc. need more power
i have the stock wt526 carb. i want o get as much power out of this engine as possible. should i find a different carb or are there any mods that give you a big boost in power.
thanks raptorhelis
Old 10-28-2004 | 12:35 PM
Default RE: best carb or mod for ryobi 31cc. need more power
What prop and RPM are you turning now?
Old 10-28-2004 | 03:08 PM
i want to put it in a prop jet. i see that people are using a 18x8 so i guess some where around there.
Old 10-28-2004 | 03:51 PM
wt526 carb has 7.94 mm venturi would look for replacement carb in 9-11 mm range.
FWIW: Walbro 167-A is 11.11 mm
Have you made any adjustment to reed stop to allow reed to open further? I adjusted mine to allow 1/8" allen wrench to slip between stop and reed.
