QUADRA 35 WITH POINTS TO "CDI "
Hy guys,
I have an old Quadra 35 cc with points and now i´m converting to Quadra 35 CDI, (I HOPE)
If anyone have pictures for the sensors fixing please, i need to see.
Yesterday the engine weight is 2 kg. (4,4 lb) and today without ignition, 1,4 kg (3.1 lb)
Please y need pictires for the cdi instalation on quadra engine.
Sergio
Sergio
RE: QUADRA 35 WITH POINTS TO "CDI "
I have not photos to you but I have the converted engine, I put a litlle fly wheel (5cm dia) with the magnet inserted then the prop hub, the hall sensor in a 1mm dural sheet, I will take the photos as aoon as I can. Take a look at:
www.hpignitions.com.ar
First you finish the Epsilon!!!
I´m working in the 80" Extra again, also with the US 35 on ignition....hope to have it for the "Volando Entre Volcanes 2005"
Tato.
Tato.
Dear Tato
I want to go to Volando entre volcanes!!!! please tell us when where etc.
You saw the engine running at Volando en el Newbery, no kik back hand start low idle etc.
hasta la vista!
hasta la vista!
Platero:
I´m sending you all the info about the event, if anyone is interested just email me at [email protected]
Platero, thanks for your direction, i see all the instructions to put the cdi...
Tato, i want to go to Puerto Varas with my Epsilon and With the " tractor 300 " I´m waiting Haral send my cdi soon. The Epsilon of Haralt i begun to build next week (my wife go to LLanquihue) .
Tato please send the day to the event on Puerto Varas,..,....,wdtrnhipowehjrpigwhjeripyh
me cuesta mucho el ingles, por fa mandame la fecha exacta del aeropicnic de Pto Varas ya que me tengo que organizar y no faltar, se que van algunos buenos pilotos Argentinos y Platero tambien quiere ir , se ve muy interesante que llege alguien con encendidos electronicos para ver alternativas y tambien para que nos enseñen algunas triquiñuelas....
Espero convencer a algunos Temucanos para llegar en grupo.
con respecto al Quadra esta entero desarmado, espero poder llevarlo, pero lo mas seguro es que lleve solo el Epsilon.
See you soon...
sorry for the spanish, for me is so dificult writte english, thanks.
Sergio
See you soon...
Sergio
The event is on january, saturday 29 and sunday 30.
BUT on friday 28 after the helis and static show in the main square at Puerto Varas city, next to the lake, we will move to the club at noon to have a "Curanto", very tipical southern chilean food event in wich the exquisit sea food is cooked along with chicken, pork and beefs all in the same big aliminum bowl, and covered with "Nalca" leaves.
Also includes "Milkao" and "Chapaleles"... all of you who would like to try, just have to come over. ( this is all offered by the club for free to the r/c visitors)
WHERE IS THE BEST PLACE TO PUT THE CAPTOR, OVER OR ON THE SIDE????????
I SEE THE 2 FORMS ON DIFERENTS PICTURES.
Sergio,
El US, como el quadra, no tiene ningún a protuberancia del carter que continue a lo largo del cigueñal que permita poner una abrazadera a la cual pegar el sensor por encima del volante que irÃ*a insertado desde afuera apuntando al centro del cigueñal. como en la foto.
Ñuiego, lo mejor es hacer una pieza de aluminio delgado o latón que se paerna los mismas bases donde va la bobina . esta pieza se prolonga hasta abajo y por atrás lleva pegado el imán que apunta desde el motor hacia la hélice por atrás del volante que soporta el iman, En este caso el imán va horizontal ( paralelo) al cigueñal).
Te adjunto las fotos, tu tiernes que ver como te es más facil la instalación en tu motor e idear algo en base a eso.
tato.
tato.
