Throttle cables
Old 02-01-2005 | 09:00 PM
My Feedback: (25)
Default Throttle cables
Can I use a metal cable or metal push rod for the throttle on a Poulan 25cc motor. I have read that it will cause RF interference if you use a metal cable from the servo to carb. What are you using.
Old 02-01-2005 | 09:28 PM
Default RE: Throttle cables
You need to use a nylon push rod(goldin rod) not any metal to metal.
Old 02-01-2005 | 10:37 PM
w8ye's Avatar
My Feedback: (16)
Sullivan has a newer rod that has a white sheath and a black rod. It has a lower coefficient of expansion and there will be fewer throttle trim changes with the changes in ambient temperature.
Make sure you keep the plastic rod away from the muffler heat. It will melt.
Enjoy,
Jim
Old 02-24-2005 | 06:53 PM
platero's Avatar
everything what can fail, is going to fail, the metal push rod can act like antenna, and it will do!
