Tap an old spark plug for glow?
My Feedback: (10)
Anyone ever tapped an old spark plug for a glow adapter? I could buy one for $14 but just wanted to experiment on my 33cc Poulan
Also, what if you don't increase the area of the walbro jets for glow fuel? Will it not run?, be low power? I don't know if I like the idea of messing with the carb. Any easy ways to do this?
El Cheapo
El Cheapo
DC
RE: Tap an old spark plug for glow?
You can tap a 14 mm plug for a CM6, but not a 1/4 32 glow plug...
Most standard carbs won't pass enough fuel for glow..Check with Dick at B&B, I think he has some info on making glow carbs .....
www.bennettbuilt.com
If the hole left from removing the porcelin is small enough you can tap the hole directly. If not then the hole needs to be filled and then drilled and tapped for the glow plug.
The carb if not modifed will be lean.
You can gut a spark plug if you're careful. I've done a number of them to make a fitting to inject air into cylinders. You have to clamp it in a vise and work slowly, and with protective glasses. Just keep chipping away at the porcelin until you get it and the center electrode out. If you drive out the center electrode first, then it's easier to collapse and knock out the porcelin. My thought for making a glow plug adapter would be to then make a small piece of metal and weld or braze it into the end of the spark plug. Then drill and tap that for a glow plug. You may have to drill the upper metal part of the spark plug for your glow plug wrench depending on how thick it is.
Just my ideas,
AV8TOR
Just my ideas,
AV8TOR
ON, CANADA
Out of curiosity,where abouts should the glow plug be located inside the spark plug adapter?Should it be level with the bottom,slightly out the bottom,up inside?Has anyone got a picture of one of these things for us to study up close and use as a reference?
If you have a lathe you can make the whole adapter out of ally in about 20 minutes.(granted it has to be a thread cutting lathe)
My Feedback: (10)
I don't think the specs would be that strigent as the glow plug just needs to ignite the fuel and it is hot all the time when starting and running. Probably as close to the inner tip as you could get would be best in order to stay hot.
DC
Best to make it as close to flush as possible...I put a CM6 NGK spark plug, short reach, in a G26 to make it shorter from the crank to the top of the spark plug...Lost 2 or 300 rpm because of the loss of compression due to the extra space in the combustion chamber...
I do not think you even need a thread cutting lathe. Just turn the stock to the right dia and use a thread die to make the external threads. Tap for internat threads. You may not even need a lathe...if you can find stock the right dia. Added..... another Idea.....find a bolt with the same threads as the spark plug you took out and cut it to right length and drill & tap it to make a adapter. Capt,n
TN
I read this thread yesterday and after exhausting myself for about 20 minutes trying to drill the electrode out of an old spark plug, my mind started wondering if there was anything else that would work better...A 14 mm piston stop for adjusting valves on a 4 stroke. Its all aluminum and a much easier conversion. I also drilled the seat for the needle valve and the high speed adj screw in the carb to flow more fuel. The engine is still in a Stihl weedeater as of now but even with a clutch, driveshaft, gearbox, and cutting head it had good power on 15% nitro. Now if I could only find a purpose for doing this...
TN
Yes you can run glow fuel through a walboro or zama carb if you drill out the port where the needle valve rests. These needles have a viton (rubber) tip and dont require a rubber seat. This allows you to actually ream out the hole just a litte. one or two drill bit sizes. The needle will fall into the hole a little farther after you ream it so be sure to bend the tang down that holds the needle to counter the modification. Also you may want to ream the high speed mix screw as well to flow more fuel. And one last note, correct me if I'm wrong but it seems to me since nitro carries its own oxygen and we are trying to cut down on the amount of air in the air/fuel mix a lower nitro content might help. I ran mine on 15% which may be a bit on the high side? Anyone?
ON, CANADA
Don't know if your aware already or not but Peter at Wacker Engines does sell a glow plug adapter($15) as well as the glow prop hub($20) designed to fit straight onto the end of the crankshaft:
http://prophub.tripod.com/
The Zenoah glow plug adapter designed to fit the G23 or G26 is also available from Horizon for $9.95(ZEN23445).I guess it all depends on what size engine and plug your trying to convert.
ON, CANADA
Wonder why you just couldn't make an intake manifold adapter to take a large Supre Tiger glow carb(ST2500 etc?) and just use muffler pressure to pressurize the gas tank like any other glow airplane 2 stroke?
Turbo B: I am sure you can. A perry pump or any pump will get the fuel to carb and may make for more steady running over muffler pressure. You can also make a pump from a old walbro carb. There is pics how...look in search mode. Capt,n
My Feedback: (10)
About the St carb idea. It would work but I'm going to experiment with the stock WT-324 to see what kind of performance I get. I'm a cheap SOB and would have to purchase the carb and fabricate the manifold. As soon as I can get everything together annd fired up I'll post my results.
ON, CANADA
ORIGINAL: RCIGN1
If you have a lathe you just turn down the top part of the metal and the porcelain falls out in one piece
MI
Does anyone have any actual experience using any petroleum-based fuel with platinum-wire glow plugs? I remember some earlier threads ( Spark-to-Glo Conversions ) that referred to using unleaded gasoline, white gas, naphtha, Coleman stove fuel, or Walmart Yukon Trail camp fuel alone or mixed with alcohol. I understand that the platinum-wire glo plugs are primarily intended to ignite alcohol. Will they ignite any petroleum products at all? The reason for my interest is not so much to save fuel cost, but to use the gasoline fuel jetting and avoid damage to carburetor gaskets caused by alcohol. Thank you.
DC
5 minutes once a year to replace $5 worth of parts...What a chore....
The part of the spark plug just above the hex is what you cut off to take the porcelain out..A Dremel will do it just fine, just takes longer......The porcelain is cemented in but comes out easily when the metal is cut off..I usually take about half the hex off, leaving just enough for a wrench to tighten it in the head....
A glow plug won't ignite gasoline.....
