WALBRO WT-570-1
NY
WALBRO WT-570-1
My ryobi 725 from Harbor came with a Zama Carb. Unfortunately, the throttle arm on the zama is so short that I didn't think I could attach a nose wheel arm to make the throttle less sensitive (1/3 throttle on my hitec eclipse is full throttle on the zama).
On the spur of the moment I bought a Walbro WT-570-1 off ebay (see pictures attached). The carb is stamped 939 / wt570
According to the walbro tech specs at:
http://wem.walbro.com/walbro/product...m=WT%2D570%2D1
this carb has a 11.13 mm venturi.
I have 3 questions and help from the engine intelligensia is appreciated:
1) In general, is this an appropriate carb for my Ryobi
2) The fuel in and return valves are on the same size (i.e. no bent brass tube for fuel in). Which is which?
3)Was there a good way to attach a new arm to my zama give the very short throttle arm?
Thanks!
Steve
Thanks!
Steve
NY
RE: WALBRO WT-570-1
And for those of you keeping score at home, here are two snaps of my zama already mounted with the very short thottle arm and temporary linkage (clevis). How to extend that throttle arm?
RE: WALBRO WT-570-1
#1 yes; #2 open the side cover with the single center screw and see which fitting feeds into that side of carb; that is the supply line from clunk in tank
Does the zama throttle shaft extend far enough on the opposite side to install a dura collar stop?
If so, soder a brass stock arm onto collar and rotate the carb 180 degrees. Modify the carb adapter plate to assure the pulse hole lines up to new location.
NY
RE: WALBRO WT-570-1
On my stock Zama there is no throttle shaft at all on the other end.
From what I can see, the throttle arm on my Zama does not hit the back of the engine before it hits full throttle.
SC
RE: WALBRO WT-570-1
The arm on your carb should be the the same length as the arm on your servo. If from the center the shaft of your arm on your carb is 1" then from the center of the servo arm should be 1" . If you have it this way your throttle will work just right.
smallplanes
smallplanes
NY
RE: WALBRO WT-570-1
My throttle arm is 1/2" and I can easily do the same on my throttle servo's arm. However, is that going to fix the issue that 1/3 throttle on my transmitter equal to full throttle? I thought the purpose of extending out the throttle arm and moving the linkage in on the servo arm was to "de-sensitize" the throttle response.
SB
SB
SC
RE: WALBRO WT-570-1
Well ive built a few planes lately and i always may the carb link and the servo link the same length. It will then move with every click of your radio. The same all the way tru. So far it has worked for me every time. This also applies to all your control links tru out the plane. Try it i bet it will fix your problem.
smallplanes
smallplanes
RE: WALBRO WT-570-1
Your servo has 120-140 degrees of max rotation. You want to use as much of that rotation as possible. (shorter servo arm)
Your carb is probably going 75-90 degrees from closed to open position. (longer arm on carb utilizes that full servo rotation better giving more resolution (finer tuning on the stick.)
Short connection at servo and a longer arm on carb works for me.
Smallplanes system works but I think he probably is not using as full of range on the servo (endpoints)
The longer arm may have a clearance problem with the back of engine. Mine did on on carb. I made an additional carb spacer out of some ac ply and 30 minute epoxy. Two pieces of glass with some 'vaseline brand release agent' made the mating surfaces nice and smooth.
A search in engines for something like carb linkages can give you a bunch of info practical and technical.
My Feedback: (16)
TN
RE: WALBRO WT-570-1
I have a similar carb to the walbro in the pic. The big tube is the fuel supply line, but what is the purpose of the other tube? Is it for a primer bulb? That is my guess since it comes in on the other side of the inlet needle valve.
