Ryobi kill switch
Old 05-19-2005 | 08:40 PM
Default Ryobi kill switch
I wasnt paying enough attention when I took the two edgers apart. I have two motors that have a coil with two spade connectors and a switch. Fine, I got that but, I have one oddball. The coil only has one spade connector and the wire looks like it goes straight to a ground. Did I lose a wire and switch? Im guessing I need to go find a new rocker switch, are they toggle off or toggle on? Thanks for any help.
Old 05-19-2005 | 09:14 PM
Default RE: Ryobi kill switch
Was it a slider switch that slid to ground? So, momentary on im guessing?
Old 05-19-2005 | 11:40 PM
w8ye's Avatar
My Feedback: (16)
When the spade is connected to the engine crankcase, -- The spark don't work no more... How's that for a double negative?
You need a good quality switch because of all the vibration. However the switches usually fail open, but that means you cannot cut the engine off with the switch.
Enjoy,
Jim
Old 05-20-2005 | 11:04 AM
Thanks, I hate going to rat shack so I wanted to make sure I got the right stuff the first time. Thanks
