Ryobi Factory Error
Old 05-28-2005 | 08:04 PM
Default Ryobi Factory Error
I converted a 28cc Ryobi a year ago and have been flying a 1/4 scale cub with it. As this left me with no string trimmer, I picked up another new one on sale. It never ran worth ____. Almost impossible to start, and when it did run, it would not rev up at all.
The problem turned out to be that the ignition timing was way off. When I compared the sick motor to the one I was flying, I could see that the timing was off (retarded) by at least 30 degrees in the sick engine. I filed off the cast in key and tightened the flywheel on the taper at the same position as the healthy motor. The motor starts fine now and revs up normally. I never determined if it was the cast key or the machined slot in the crankshaft that was off.
Just something else to watch out for!
Old 05-28-2005 | 09:15 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Ryobi Factory Error
Thanks to your knowledge gained from converting engines, you just fixed it?
Good job,
Jim
Old 05-28-2005 | 10:05 PM
Nice catch Sprotflier. Your the man. I wonder if you put both engines at TDC... top dead center...then look and see if the slot in crank is posistioned the same with each engine. Thanks Capt,n
Old 05-28-2005 | 10:16 PM
w8ye's Avatar
My Feedback: (16)
After my second Mac's crankpin chewed a hole in the backplate, I fixed one by driving the crank pin back into place with a drift and filling the hole in the back plate with JB Weld. Has held up for a few years.
Enjoy,
Jim
