stihl 25cc conversion.
Old 07-14-2005 | 10:02 PM
KenLambert's Avatar
My Feedback: (107)
Default RE: stihl 25cc conversion.
that would depend on which way you mount the engine I would think
Old 07-14-2005 | 10:09 PM
don't normal nitro's go counter clock wise?
so wouldn't i need a special prop?
or am i just really messed up and need to go to bed?
Old 07-14-2005 | 11:47 PM
KenLambert's Avatar
My Feedback: (107)
they normally run clock wise , standing behind the engine is the way you look at it .
Old 07-14-2005 | 11:57 PM
actually, i think if it runs clockwise, that would be great. you can mount the engine like how a pusher should be mount, yet you will have the luxury of choosing all the puller props!! that would be great i think. isnt it?
Old 07-15-2005 | 07:47 AM
here are some pics of what I have accomplished so far.
Please let me know if there is more metal that I should remove.
Old 07-15-2005 | 07:29 PM
  #31
KenLambert's Avatar
My Feedback: (107)
I make cnc mounting plates and prophubs and mufflers ( tig welded aluminum ) for these engines the is one on my website you can look at.
Old 07-15-2005 | 10:58 PM
  #32
As soon as I get some cash flow freed up, I'll be hitting you up for those Kenneth
Old 07-16-2005 | 09:35 AM
  #33
I'm pretty sure it turns counterclockwise like all their trimmers. The recoil starter mounts with the rope handle coming out the left side right? the stub shaft the starter bolts to should turn clockwise and the pto side will be counterclockwise. Good for puller not pusher. Thats why its such a good airplane conversion.
Old 07-16-2005 | 11:33 AM
  #34
KenLambert's Avatar
My Feedback: (107)
Tripp , I have the tooling ordered to make your parts as soon as they arive I will get on that engine .
One other thing which way does a clock turn mine all seem to be digital !!! [sm=biggrin.gif]
Old 07-16-2005 | 01:10 PM
  #35
Rupurt's Avatar
clockwise duh!
Old 07-16-2005 | 03:43 PM
  #36
My Feedback: (29)
Hi,
Clockwise isn't a problem if you use a pusher setup. You will be able to use standard props with the flat side if the blade facing to the rear. Use the metal shroud that I mentioned earlier to help draw air over the fins. It will make a cool setup. LOL
Dave
Old 07-16-2005 | 07:34 PM
  #37
I emailed Sthil, and they said it was made to go clockwise. So I'll plan accordingly.
I don't really like the idea of a pusher for 2 reasons.
1 poor prop selection
2 moves the CG way back, makes it less stable.
Old 07-16-2005 | 08:02 PM
  #38
Ralphbf's Avatar
My Feedback: (27)
You can have a pusher with out affecting the CG.
But you are dead right about prop selection.
Old 07-17-2005 | 12:10 AM
  #39
My Feedback: (29)
Hello!!
Pusher props are for engines that turn counter clockwise, not clockwise. The beauty of the engine is that it will push with standard props. With this setup you have the same selection as a tracker. You can position the engine for the best C/G either way. The only concern is cooling and a aluminum shroud will fix that.
Dave
