Engine mount question.
Old 08-03-2005 | 04:41 PM
Default Engine mount question.
I have been working on the airboat that my Stihl 25 CC engine will go on. My biggest question is how thick does the mounting plate need to be?
My design is rather simple, it will be a c channel shape, bolted into the starter holes. The flanges will be 1" long and secured to the pylons via 2 bolts on each side.
Is this design going to be strong enough? I've seen much nicer mounts on here and some sites, but my tools are pretty limited, and besides, I don't need it fancy, just functional.
Old 08-03-2005 | 08:48 PM
KenLambert's Avatar
My Feedback: (107)
Default RE: Engine mount question.
a mount that is 3/16 would be good , 1/8 will work but useally will not hold up to vibration. I use the 3/16 on mine and lighten it as much as I can without making it weak.These are pics with a 1/4 plate which is overkill but works great.
ID:	305273   Click image for larger version
