Homelite Testing
Old 08-07-2005 | 09:16 PM
carlosponti's Avatar
Default Homelite Testing
well its a start i got my homelite 25cc running today. i had to do some tweaking the high speed needle was way leaned out. but after getting it running and adjusted(mind you i am no engine expert so it may need more needle adjustment) i got it running and running good. at first i couldnt get above 4500 rpms but like i said i adjusted the carb a bit and managed on an 18-8 to get it to peak at 8500 but its rpm rating is probably only 7500 if my tach is reading right. it kept spiking but it may be due to my measurement taking skills with my gadget. i am guessing that 7500 is going to me my rpm rating on the top end. man that was nice to hear. one of my rc buddies was over as well as my father who made a comtribution to the project my making some parts like the prop hub and turning the magneto fins down. i was rather pleased to see the vibration wasnt as bad as i would have imagined. i will post pictures soon so you can see my test stand. that thing didnt budge. i made sure the test stand was sturdy since i have had previous bad experience with an engine testing. all went well and i want to thank dave wallace for his advice and rysium(whom without his video i would have given up) for inspiration this would work out.
Old 08-08-2005 | 11:13 AM
My Feedback: (29)
Default RE: Homelite Testing
Hi Carlos,
Thanks for the nice comments. Congratulations on your sucessess.
Dave
Old 08-08-2005 | 10:32 PM
w8ye's Avatar
My Feedback: (16)
Hurry with the pictures. We want to see it...
Jim
Old 08-09-2005 | 10:00 AM
Volfy's Avatar
My Feedback: (23)
If you can get that Homie 25 to pull 8500rpm on an 18x8, you've got quite a firebreather there. That would be more like what a modified Homie would do. For a run-of-the-mill Homie 25, 7500 sounds about right. Still very good power for what you invested into it, obviously.
Old 08-09-2005 | 01:47 PM
ORIGINAL: Volfy
to be honest it may have been more like a cheap ass hobbico mini-tach that was spiking by misreading however i am guessing a stable 7500 rpm and yes good for the 25 bucks or so i have in it.
w8ye i am working on that i will drop the pictures off at the 1 hour lab tonight.
Old 08-09-2005 | 07:36 PM
tkg
ORIGINAL: Volfy
Fer sure, Ive got a very special 25 Homie, it will turn an APC 16x8 @9300, an APC 18x8 is only good for 7200 RPM. Lots of HP and no torque
Old 08-09-2005 | 08:55 PM
here is the picture of my airplane engine
Old 08-09-2005 | 08:58 PM
w8ye's Avatar
My Feedback: (16)
Everything looks OK. I have a couple of those little box mufflers. I gutted them and welded in hydraulic tube exhausts.
I like them better than the aluminum jobs.
Enjoy
Jim
Old 08-09-2005 | 09:31 PM
i already gutted it and drilled holes in the bottom that you cant see from the picture however i didnt put any down chutes. but i made sure to gut the muffler because its cheaper than the aluminum mufflers.
Old 07-30-2006 | 06:47 PM
how do yu guys "gut" your mufflers? grind the edges and then solder them together?
Old 07-30-2006 | 09:13 PM
Use silver solder or braze them back together. The ones with slots....just hammer the louvers flat and weld shut. Then drill and add exhaust stub or stubs. Capt,n
