Stihl 041
Old 09-14-2005 | 09:07 PM
Antique's Avatar
Default Stihl 041
Stihl 0414 lbs, the magneto has been removed and CD electronic ignition is located inside the mount...It runs about the same as a G62...
Old 09-14-2005 | 09:53 PM
Default RE: Stihl 041
How many cc's, and what piece of equipment does this one come from?
Old 09-14-2005 | 11:16 PM
My Feedback: (29)
Hi,
Stihl chainsaw with 4.1ci or about 66cc.
Dave
Old 09-14-2005 | 11:18 PM
Ralphbf's Avatar
My Feedback: (27)
Here is a link to Stihls comparison chart.
http://www.stihl.us/chainsaws/comparison.html
The old saws started with a 0 such as 044. The new stuff starts with what the second number use to be.
Such as 440.
If you study the chart you should be able to figure it out.
Old 09-15-2005 | 01:35 AM
Antique's Avatar
This one's too old for the chart'
Stihl chainsaw models with 041 prefix..
44mm bore, 40mm stroke, 61cc...6800 rpm, 22-10 prop..
Old 09-20-2005 | 07:11 PM
My Feedback: (265)
How did you get the carb to fit the 041 and still have room for the exhaust to fit, I have a 041 engine sitting in front of me and the exhaust port and the carb port are on the same side of the cylinder very close together, one is just a little lower than the other.
Old 09-20-2005 | 09:41 PM
Antique's Avatar
My mistake...I ASSumed it was an 041 from the bore....A further search in the book shows that after serial # 6111990 the 028 was made with a 44mm bore..It's an 028, 47cc...Very impressive, it thinks it's a DA 50
Old 09-20-2005 | 10:56 PM
Who was that that said " assume nothing" HA!!!!
Old 09-20-2005 | 11:54 PM
Antique's Avatar
Tony Randall on the Odd Couple ?
Old 09-23-2005 | 04:44 PM
My Feedback: (265)
Just to clear this up, this is a Stihl 031, 59cc, 3.6 cu. in. engine, The reason I know this is my engine he converted. I like this engine because it has the same exhaust port and bolt pattern as the DA 50 so any muffler for a DA 50 will fit this engine, Great job on the engine I just got it today, thanks Dean
Old 09-23-2005 | 06:55 PM
Antique's Avatar
I looked in my book again, it says the 031 is 48cc, 3.2 cu. in...Whatever it is, it runs really good....
Old 09-23-2005 | 08:08 PM
Ralphbf's Avatar
My Feedback: (27)
Does it have a transistorized magneto or electronic ignition?
Old 09-25-2005 | 07:37 AM
My Feedback: (13)
Good morning gentlemen, it seems that there are some very knowledgable Sthil folks here so I will ask a question, I have just finished converting a Super 045 that my brother purchased new over twenty years ago. The rings were remade for me by the gentleman in NM so I know it is a 54mm bore and I measured 38mm stroke using a machinist rule and eyeing it against the edge of the spark plug hole. My calculation shows 87cc but that seems a weird number. does anyone know the official size of this thing? I ran it last week using the original muffler and have yet to decide what to use on the plane I am building for it.
Old 09-25-2005 | 11:45 AM
Antique's Avatar
The chainsaw book says it's a model 045, 87cc..Should be a strong one A 24 -10 prop should work well....
