weedeater XT50
Old 09-21-2005 | 05:41 AM
Default weedeater XT50
I was given a weedeater motor and do not know cc's and were I can get parts for conversion. Carb is on back of crank case with reed setup. I can use all the info you guys can give me plzzz!!! Thx Lureman
Old 09-21-2005 | 06:41 AM
Default RE: weedeater XT50
Post a picture and I'm sure someboby will know what it is.
Pete
Old 09-21-2005 | 11:32 AM
My Feedback: (29)
Hi,
I have a couple XT-90 trimmer motors. One is still a trimmer and the other is just the unconverted head. They are about 30cc. I beleive that the XT50 and XT20 are much smaller versions at about the same weight. The design is very much like a Ryobi 31cc with reed valve and exhust in the rear. The exhust is round exit and the muffler is held on with springs. The muffler can be modified for R/C. It may be a little heavy for its power. The crankshaft stud should be 5/16x24 thread which is easy to get. Same as Homelite 25/30cc. Here is the website for parts.
Dave
http://www.odref.com/poulan/pdf/WEED...MERS/xt-50.pdf
Old 09-21-2005 | 02:26 PM
carlosponti's Avatar
looks exactly like the same engine on my craftsman, which is a 32cc. My craftsman has those same springs holding on the muffler as well as the shape of the muffler is the same.
Old 09-21-2005 | 06:47 PM
My Feedback: (29)
Hi Carlos,
Did you finish converting the craftsman? If you did, how did it run?
Dave
Old 09-22-2005 | 08:41 AM
havent had much chance to do anything with it. for one thing the carb only has the one adjustment and i have been busy building a Chipmink for someone. i need to get back on it soon i think.
