Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
 Another spring starter question Poulan 55cc >
Old 10-11-2005 | 07:35 AM
My Feedback: (131)
Default Another spring starter question Poulan 55cc
Now that I have a source for chainsaw engine sizes, I gotta figure how to start the thing. From what I've read, the 46cc Poulan will use the Bennett Us41 spring starter.
If I go with the 55cc Poulan, has anyone figured out what kind of spring starter would work with it?
Also, are these engines converted with the stock carb, or is a better carb perferred for real horsepower?
Thanks so much!
Old 10-11-2005 | 08:23 AM
w8ye's Avatar
My Feedback: (16)
Default RE: Another spring starter question Poulan 55cc
The stock carb should be fine as long as it has two needles. A chain saw generally has a good carb.
Old 10-11-2005 | 12:59 PM
My Feedback: (29)
Hi 100,
If the 46cc and the 55cc take the same clutch, they will take the same spring starter. You just need a place to screw down the end of the spring.
Dave
Old 10-11-2005 | 03:14 PM
My Feedback: (131)
This is good information, Thanks!!!
