Mac Engined ID help (upotate: Kiortz?)
Old 10-12-2005 | 10:55 AM
sscherin's Avatar
Default Mac Engined ID help (upotate: Kiortz?)
Here's the pics..
All the McCulloch's I found pics of had straight plug heads.. this one is an angle.
I'll post better pics when I get it stripped down.
Old 10-12-2005 | 11:51 AM
Default RE: Mac Engined ID help
Might be a kiortz.
Old 10-12-2005 | 12:23 PM
sscherin's Avatar
I think you got it..
If I can figure out how to get the stupid clutch off I'll take it apart and check the bore/stroke
It's a little dirty but turns smooth.
Here's the new pics.
Old 10-12-2005 | 12:48 PM
Antique's Avatar
Might look like Echo, but I think ALL Eager Beavers were McCullochs..Most had roller bearings on the crank..If it's a Kioritz/Echo there will be a stylized E somewhere on the engine, looks like 3 trianges horizontally on top of each other..
Old 10-12-2005 | 01:19 PM
[quote]ORIGINAL: sscherin
[quote]
Look on the base of the cylinder it might say what the cc's are.
Pete
Old 10-12-2005 | 01:21 PM
sscherin's Avatar
Default RE: Mac Engined ID help (upotate: Kiortz?)
more info
# on the bottom of the engine case is 400032B and below that a long serial number
Carb is a Zama C1S stamped M8 5ZP on the front.
Old 10-12-2005 | 01:29 PM
Look along the base of the cylinder for a number.
Pete
Old 10-12-2005 | 04:41 PM
sscherin's Avatar
There is a 4 cast in the base of the cylinder section of the case.. No other numbers anywhere except the McCulloch PN 400032b.
I found out that is the Trimmer model number.
The bore is 32.25mm
Stroke (best guess) 24mm
that comes out to 21cc??
Old 10-12-2005 | 05:13 PM
My Feedback: (29)
Hi,
I have one just like it. Mine came from a Mac Road Runner trimmer. It is 21cc. To remove the clutch, clamp the clutch guide in a vise, jam the flywheel with a screw driver through the flywheel fins and against the shroud. Turn the block. It is a 8x1.25mm stud at both ends. The timing is very conservative at: Intake 110 degrees duration,exhust 120 degrees duration, transfer 90 degrees duration. It looks like it was made by Koiritz for McCulloch. The ring is floating. Very heavy fly flywheel at about 12oz. Good quality.
Dave
Old 10-12-2005 | 06:29 PM
I have 2 Macs 1 has a 28 on the cylinder and the other is a 32. I thought yours might be similar although yours has an angled plug like my Echo.
Pete
Old 10-12-2005 | 08:34 PM
w8ye's Avatar
My Feedback: (16)
The 28 and 32 have a straight plug and the muffler is held on by a spring loaded wire.
Enjoy,
Jim
