Cox Medallion .15 conversion C/L to R/C
Old 10-28-2005 | 04:04 PM
Default Cox Medallion .15 conversion C/L to R/C
I'd like to convert my COX .15 Medallion, originally bought for C/L, to R/C. I have an R/C cylinder/piston/rod set (Cox 2268) and assume it will screw into the original C/L crankcase but don't know if there are any other differences I should be aware of. Anyone got any idea ?
Old 10-28-2005 | 08:53 PM
Default RE: Cox Medallion .15 conversion C/L to R/C
YES.. try screw-ing cyl in place. If threads are right it will go. Do not force it or cross thread it. If it goes into place and engine turns over with same compression...it should work. Good Luck Capt,n
