S/S electronic ignition (Pics Added)
Old 11-08-2005, 02:58 PM
blueberry
Default S/S electronic ignition (Pics Added)
I recently purchased an electronic ignition second hand it says S/S ignition on it.
Does anybody know anything about this brand or know how to contact them?
The guy I purchased it from said he bought it at the Weak Signals RC Show in Toledo Ohio.
Pete
Old 11-11-2005, 10:53 PM
blueberry
Default RE: S/S electronic ignition
Anybody?
Old 11-12-2005, 01:19 AM
davewallace
My Feedback: (29)
Hi Berry,
Post a picture of the unit and the circuit board and see if anyone recognizes it.
Dave
Old 11-12-2005, 08:21 PM
blueberry
Ok Dave here are some pics.
The first problem I was having was that when the plug fired it would also jump a spark from the plug cap to the outside of the plug. I beleive I solved that by grounding the sheilded wire.
Second is the yellow wire coming out of the box, I have no idea what that is for?
Third I don't know if I can run 6 volts or if I should just stick with 4.8 volts. The spark does look pretty good with 4.8volts.
Sorry for all the questions this is my first electronic ignition.
Pete
ID:	353209   Click image for larger version
Old 11-12-2005, 08:50 PM
Antique
Antique's Avatar
Could be a secondary ground wire...Check for contunuity between the shielding and the wire...An ignition needs to be grounded..The shield is normally connected to the ground somewhere...
Old 11-12-2005, 09:53 PM
blueberry
ORIGINAL: RCIGN1
It does have continuity and I just tried grounding the yellow wire and that seems to work.
I have to get a new battery pack though. The one that I got with it must be junk because I charged it and I can only get a few sparks and then the voltage drops too low and I don't get any spark.
Pete
Old 11-12-2005, 10:22 PM
tkg
Not much help, but he was upstairs in the swapmeet section. Didn't get a card so no joy.
Old 11-12-2005, 10:27 PM
blueberry
Thanks That might help.
Did you happen to look at his ignitions or ask any questions?
Pete
Old 11-13-2005, 09:05 PM
Eagle Flyer
My Feedback: (84)
The yellow wire is a ground.
Old 11-18-2005, 09:09 PM
Prop Nut
Prop Nut's Avatar
Default RE: S/S electronic ignition (Pics Added)
S/S Machine and Engineering, LLC
Specializing in Prototypes, AlloyMachining adn Anodizing
Roy Sholl-President
16940 Co. Rd. T Fayette, Oh, 43521
419 452-7490
www.cncengines.com
Hmmm, sorry that I dont have very much information on S/S to give you. Hope this helps
I talked to the guy at Toledo last spring, he seemed very knowledgable and friendly. He had several demo motors set up. His web site has good information to help set up that system.
Old 11-18-2005, 09:23 PM
blueberry
Thanks Prop Nut!
That is what I was trying to find. When I get a hub made I will post here how it works.
All that I have done so far is bench test it and it does seem to have a nice spark.
Pete
Old 02-12-2006, 11:16 PM
Scott Ellingson
My Feedback: (146)
Scott Ellingson's Avatar
I have been dealing with Roy Sholl for a while now. He is a great guy. Any questions you have he will be happy to answer. You are correct on the shielded wire. It needs to touch the metal part of the plug. The silicon on the cap is to hold the braided wire aginst the plug. The ignition was designed to run at 4.8v. DO NOT run a 6volt battery to it. The max input voltage is 5.4 volts. The unit you have he does not make anymore. It is a fixed timing unit and all he currently makes is an auto advance unit. I have one of his old fixed timing units as well as a bunch of the variable timing units. My fixed timing does not have the extra ground. That must be somthing he changed since yours was made.
Old 02-13-2006, 12:18 PM
blueberry
poco242,
Yeah Roy seems like a good guy to deal with. He e-mailed me and sent me an update kit for my ignition no charge! I bought this ignition second hand from a guy not from Roy directly, anybody that would do that is ok in my book! I will definetly buy my next ignition from him!
Pete
Old 08-11-2006, 11:30 PM
TIGITRIGHT
Roy is a very nice guy and friendly to deal with.You got a good ignition there.[sm=thumbup.gif]
Old 08-15-2006, 10:37 PM
billzair
My Feedback: (29)
I bought an ss ignition about 6 months ago.....finally about to set it up on a 55cc craftsman Anyway, I never got the little magnet that you epoxy into the prop hub to fire the plug......is that something that I should have bought seprate, or ??? Can I get one at radio shack or something..
thanks for the help guys!
Jon
Old 08-16-2006, 12:27 AM
blueberry
ORIGINAL: billzair
Jon
billzair,
Check post #10 it has Roy's number give him a call and I bet he can set you up.
Pete
Old 08-16-2006, 07:35 AM
Eagle Flyer
My Feedback: (84)
Let us know how the 55 does......
Old 08-17-2006, 06:58 AM
coralcape
Yep. You can get those little magnets at Radio Shack. They come two to a blister pack. I use the 1/4" size. Make sure you test on ignition before epoxing to pickup ring. They have to be oriented correctly. Good luck, red
