gas plug conversion for .40
Old 12-04-2005 | 09:55 AM
Default gas plug conversion for .40
I read about this long ago it was being tested in the 90's ,,does anyone still make a conversion kit to run a .40 size engine on spark with gas and oil???.....yes it was made, I think around 94 there was a review in RCM on it...Rog
Old 12-04-2005 | 10:32 AM
Antique's Avatar
Default RE: gas plug conversion for .40
Easy enough to do, but more trouble than it's worth, costs abot $150....
The carb gets really touchy....Just as messy as a glow engine, you use the same amount of oil in the fuel...
Old 12-04-2005 | 10:35 AM
w8ye's Avatar
My Feedback: (16)
The four stroke glow engines adapt real well to ignition but to still use glow fuel. They are really nice running. The ones I've been around were in the 90 and 120 size. It still cost $150.
Enjoy,
Jim
Old 12-04-2005 | 03:40 PM
tkg
A .40 is sorta small for conversion, unless you have a special need.
The parts can be found at www.ch-ignitions.com
Old 12-04-2005 | 04:58 PM
Thanks fellas! I knew I remembered reading about it!!...Rog
