need a walbro link
www.walbro.com Then click on "SERVICE AND AFTERMARKET" on the left. When that page loads, then click on "AFTERMARKET PARTS AND SERVICE". Then you're on the page to search manufacturer or part number.
AV8TOR
AV8TOR
My Feedback: (16)
This was posted on here some time back.... I cannot remember who actually compiled this list?
Walbro Carburetors
11.11mm
WT-105-1, No Choke, No Primer, 1 Needle (no low speed)
WT-108-1, No Choke, No Primer, 2 Needles
WT-130-1, No Choke, No Primer, 2 Needles
WT-131-1, No Choke, No Primer, 2 Needles
WT-139-1, No Choke, Primer, 2 Needles
WT-144-1, No Choke, No Primer, 2 Needles
WT-145-1, No Choke, Primer, 2 Needles
WT-146-1, No Choke, No Primer, 2 Needles
WT-214-1, Choke, No Primer, 2 Needles
WT-239-1, Choke, No Primer, 2 Needles
WT-243-1, Primer, No Choke, 2 Needles
WT-249-1, Choke, No Primer, 2 Needles
WT-250-1, No Choke, No Primer, 2 Needles
WT-252-1, No Choke, No Primer, 1 Needle (no high speed)
WT-258-1, Choke, No Primer, 2 Needles
WT-261-1, No Choke, No Primer, 2 Needles
WT-265-1, No Choke, Primer, 2 Needles
WT-271-1, No Choke, No Primer, 2 Needles
WT-289-1, Choke, No Primer, 2 Needles
WT-29-1, No Choke, No Primer, 2 Needles
WT-297-1, No Choke, Primer, 2 Needles
WT-301-1, No Choke, No Primer, 2 Needles
WT-323-1, No Choke, No Primer, 1 Needle (no high speed)
WT-324-1, Choke, No Primer, 2 Needles
WT-337-1, No Choke, No Primer, 2 Needles
WT-347-1, Choke, No Primer, 2 Needles
WT-348-1, Choke, No Primer, 2 Needles
WT-350-1, Choke, No Primer, 2 Needles
WT-356-1, No Choke, No Primer, 2 Needles
WT-358-1, No Choke, No Primer, 2 Needles
WT-378-1, Choke, No Primer, 2 Needles
WT-382-1, No Choke, No Primer, 1 Needle (no high speed)
WT-391-1, Choke, No Primer, 2 Needles
WT-40-1, No Choke, Primer, 2 Needles
WT-404-1, No Choke, Primer, 2 Needles
WT-407-1, No Choke, No Primer, 2 Needles
WT-410-1, No Choke, No Primer, 2 Needles
WT-415-1, No Choke, Primer, 2 Needles
WT-42-1, No Choke, No Primer, 2 Needles
WT-433-1, Choke, No Primer, 2 Needles
WT-437-1, Choke, No Primer, 2 Needles
WT-438-1, Choke, No Primer, 2 Needles
WT-462-1, No Choke, Primer, 2 Needles
WT-464-1, No Choke, No Primer, 2 Needles
WT-47-1, No Choke, No Primer, 2 Needles
WT-478-1, No Choke, No Primer, 2 Needles
WT-499-1, No Choke, No Primer, 2 Needles
WT-504-1, Choke, No Primer, 2 Needles
WT-511-1, No Choke, No Primer, 2 Needles
WT-516-1, No Choke, No Primer, 2 Needles
WT-517-1, No Choke, Primer, 2 Needles
WT-518-1, Choke, No Primer, 2 Needles
WT-522-1, Choke, No Primer, 2 Needles
WT-524-1, No Choke, Primer, 2 Needles
WT-527-1, No Choke, No Primer, 2 Needles
WT-530-1, No Choke, No Primer, 2 Needles
WT-534-1, Choke, Primer, 2 Needles
WT-551-1, No Choke, Primer, 2 Needles
WT-553-1, No Choke, Primer, 2 Needles
WT-563-1, No Choke, No Primer, 1 Needle (no high speed)
WT-568-1, Choke, No Primer, 2 Needles
WT-569-1, Choke, No Primer, 2 Needles
WT-572-1, Choke, No Primer, 2 Needles
WT-576-1, Choke, No Primer 2 Needles
WT-588-1, Choke, No Primer, 2 Needles
WT-613-1, No Choke, Primer, 2 Needles
WT-624-1, Choke, No Primer, 2 Needles
WT-625-1, Choke, No Primer, 1 Needle (no high speed)
WT-626-1, Choke, Primer, No Needles
WT-627-1, Choke, No Primer, 1 Needle (no high speed)
WT-628-1, Choke, No Primer, No Needles
WT-629-1, No Choke, No Primer, 1 Needle (no high speed)
WT-630-1, Choke, Primer, 1 Needle (no high speed)
WT-631-1, No Choke, Primer, 1 Needle (no high speed)
WT-634-1, Choke, No Primer, 1 Needle (no high speed)
WT-642-1, Choke, No Primer, 2 Needles
WT-662-1, Choke, No Primer, 2 Needles
WT-669-1, Choke, No Primer, No Needles
WT-678-1, Choke, No Primer, 2 Needles
WT-684-1, No Choke, No Primer, 1 Needle (no high speed)
WT-689-1, Choke, No Primer, 2 Needles
WT-690-1, Choke, No Primer, 2 Needles
WT-695-1, Choke, No Primer, No Needles
WT-698-1, Choke, No Primer, No Needles
WT-700-1, Choke, No Primer, 2 Needles
WT-702-1, Choke, No Primer, 2 Needles
WT-707-1, Choke, No Primer, 2 Needles
WT-709-1, Choke, No Primer, 2 Needles
WT-718-1, Choke, No Primer, no needles
WT-72-1, No Choke, Primer, 2 Needles
WT-729-1, Choke, No Primer, 2 Needles
WT-74-1, No Choke, No Primer, 2 Needles
WT-77-1, No Choke, No Primer, 2 Needles
WT-86-1, Choke, No Primer, 2 Needles
WT-88-1, Choke, No Primer, 2 Needles
WT-94-1, No Choke, No Primer, 2 Needles
11.11mm
WTA-12-1, Choke, No Primer, 1 Needle (no high speed)
WTA-13-1, Choke, NO Primer, 1 Needle (no high speed)
WTA-14-1, No Choke, No Primer, 1 Needle (no high speed)
WTA-15-1, No Choke, No Primer, 1 Needle (no high speed)
WTA-2-1, Choke, No Primer, 1 Needle (no low speed)
WTA-3-1, Choke, No Primer, 1 Needle (no high speed)
WTA-4-1, Choke, no Primer, 1 Needle (no high speed)
WTA-5-1, Choke, no Primer, 1 Needle (no high speed)
WTA-6-1, No Choke, No Primer, 2 Needle
WTA-7-1, No Choke, no Primer, 2 Needle
WTA-9-1, Choke, no Primer, 1 Needle (no high speed)
11.11mm
WA-137-1, No Choke, No Primer, 2 Needles
WA-138-1, No Choke, No Primer, 2 Needles
WA-144-1, No Choke, No Primer, 2 Neesles
WA-150-1, No Choke, Primer, 2 Needles
WA-154-1, No Choke, Primer, 2 Needles
WA-162-1, No Choke, No Primer, 2 Needles
WA-166-1, No Choke, No Primer, 2 Needles
WA-167-1, No Choke, Primer, 2 Needles
WA-173-1, No Choke, No Primer, 2 Needles
WA-174-1, No Choke, No Primer, 2 Needles
WA-175-1, No Choke, No Primer, 2 Needles
WA-190-1, No Choke, No Primer, 2 Needles
WA-192-1, No Choke, Primer, 2 Needles
WA-193-1, No Choke, Primer, 2 Needles
WA-196-1, No Choke, No Primer, 2 Needles
WA-197-1, No Choke, No Primer, 2 Needles
WA-203-1, No Choke, No Primer, 2 Needles
WA-208-1, No Choke, No Primer, 2 Needles
WA-210-1, No Choke, No Primer, 2 Needles
WA-213-1, No Choke, Primer, 2 Needles
WA-222-1, No Choke, No primer, 2 Needles
WA-55-1, No Choke, No Primer, 2 Needles
11.11mm
HDA-113-1, No Choke, Primer, 1 Needle (no high speed)
HDA-131-1, No Choke, No Primer, 2 Needles
HDA-135-1, No Choke, Primer, 2 Needles
HDA-147-1, Choke, Primer, 2 Needles
HDA-149-1, No Choke, Primer, 2 Needles
HDA-155-1, Choke, No Primer, 2 Needles
HDA-168-1, Choke, No Primer, 2 Needles
HDA-169-1, Choke, No Primer, 2 Needles
HDA-201-1, Choke, No Primer, 1 Needle (no high speed)
HDA-206-1, Choke, No Primer, no Needles
HDA-210-1, Choke, No Primer, 2 Needles
HDA-220-1, Choke, No Primer, 2 Needles
HDA-59-1, Choke, No Primer, 2 Needles
HDA-60-1, Choke, No Primer, 2 Needles
HDA-64-1, Choke, No Primer, 2 Needles
HDA-70-1, No Choke, Primer, 2 Needles
HDA-90-1, Choke, Primer, 2 Needles
11.13mm
WT-15-1, No Choke, No Primer, 2 Needles
WT-21-1, No Choke, No Primer, 2 Needles
WT-570-1, Choke, No Primer, 2 Needles
WT-8-1, Choke, No Primer, 2 Needles
WT-83-1, No Choke, No Primer, 2 Needles
WT-9-1, Choke, No Primer, 2 Needles
11.13mm
WA-106-1, No Choke, No Primer, 2 Needles
WA-1-1, No Choke, No Primer, 2 Needles
WA-112-1, No Choke, No Primer, 2 Needles
WA-113-1, No Choke, No Primer, 2 Needles
WA-115-1, No Choke, No Primer, 2 Needles
WA-126-1, No Choke, No Primer, 2 Needles
WA-133-1, No Choke, No Primer, 2 Needles
WA-141-1, No Choke, No Primer, 2 Needles
WA-142-1, No Choke, No Primer, 2 Needles
WA-151-1, No Choke, No Primer, 2 Needles
WA-155-1, No Choke, No Primer, 2 Needles
WA-18-1, No Choke, No Primer, 1 Needle (no high speed)
WA-19-1, No Choke, No Primer, 2 Needles
WA-200-1, No Choke, No Primer 2 Needles
WA-25-1, No Choke, No Primer, 2 Needles
WA-32-1, No Choke, No Primer, 2 Needles
WA-33-1, No Choke, No Primer, 2 Needles
WA-34-1, No Choke, No Primer, 2 Needles
WA-39-1, No Choke, No Primer, 2 Needles
WA-44-1, No Choke, No Primer, 2 Needles
WA-53-1, No Choke, No Primer, 1 Needle (no high speed)
WA-54-1, No Choke, No Primer, 1 Needle (no high speed)
WA-58-1, No Choke, No Primer, 2 Needles
WA-64-1, No Choke, No Primer, 2 Needles
WA-65-1, No Choke, No Primer, 2 Needles
WA-73-1, No Choke, No Primer, 2 Needles
WA-75-1, No Choke, No Primer, 2 Needles
WA-78-1, No Choke, No Primer, 1 Needle (no high speed)
WA-8-1, No Choke, No Primer, 2 Needles
WA-85-1, No Choke, No Primer, 2 Needles
WA-86-1, No Choke, No Primer, 2 Needles
WA-92-1, No Choke, No Primer, 1 Needle (no low speed)
WA-96-1, No Choke, No Primer, 2 Needles
WA-99-1, No Choke, No Primer, 2 Needles
Walbro Carburetors
11.11mm
11.11mm
11.11mm
11.11mm
11.13mm
11.13mm
