Hommi 30 question
My Feedback: (16)
I run a 18-8 Dyna Thrust on mine. Seems to do will. It sounds correct up in the air. Runs about 7500 with the magneto ignition.
I have another not on a plane but it will turn the same prop around 8200. It has C-H ignition.
This depends on how else the engine is modified.
The C-H ignition by itself will not change which prop to use.
Enjoy,
Jim
Enjoy,
Jim
