OPS30 Glow to Gas
If I had that OPS 30cc I would get a carb just for gas. Next to free off a broken chain saw. Then all you would have to do is switch carbs and run gas or glow. You can leave the CH ignition on for better idle...ect. Good Luck Capt,n
I am saying if you put the ignition on...you can run a gas carb set up, tuned for gas or you can run glow fuel with the orginal glow carb on it...still using the ignition. No glow to blow out...I would say it will run better with spark ignition. The sparks are there but sometimes glows die out. I do not know how better to explain it. Good luck Capt,n
