stihl ms 250
Old 03-31-2006 | 08:55 PM
Default stihl ms 250
Just started converting a stihl ms250.Any thouths on how to mount the coil to engine.[]
Old 04-01-2006 | 04:18 PM
flyjoe540's Avatar
Default RE: stihl ms 250
moreoctane
put electronic ignition on it. saves weight, performs better,
Iam not familiar with this engine what size is it what was its former job blower ,weed trimmer etc.
apparently the magneto is not mounted to the engine. a mount must be fabricated to hold the magneto
near the flywheel to generate a spark , it would have to be stable and solid unafected by vibrations and G-loadand it would have to be adjustable to time the ignition . it would be easyer to put a cd ignition on it , lighter and better performing too
however it would be more expensive.
Old 04-02-2006 | 02:02 PM
Since the carburetor mounts on the nylon main housing instead of the engine on this saw, how will you mount it? I'm sure you could build a bracket and use the original rubber manifold - is that your solution?
Old 04-02-2006 | 10:25 PM
was just on ch site,which ignition should i order.
Old 04-16-2006 | 07:13 PM
tim220225's Avatar
The ones I use for under 44cc are the regular CH ignition box and I like the Bosch cap. Anything 44cc and up I use the Syncrospark version of the same ignition. Less chance for kickback on the bigger thumpers. Bosch caps eliminate the ground strap and look cleaner installed.
Old 04-16-2006 | 07:31 PM
KenLambert's Avatar
My Feedback: (107)
I make a carb adapter that fits them and eliminates the rubber boot
