four stroke weight?
Old 04-15-2006 | 01:24 AM
Default four stroke weight?
I have been searching for 4 hours and I cant find the info I need
bare engine weight
honda
shindaiwa
briggs&stratton
thanks
Darin
Old 04-15-2006 | 01:54 AM
subarubrat's Avatar
Default RE: four stroke weight?
GX35 5Lbs 7oz with carb, mount, prop, prop adapter and a 6 inch header
GX31 4Lbs 14 Oz with stock muffler, mount, and prop adapter.
Old 04-15-2006 | 10:37 AM
Antique's Avatar
I have converted all 3 and put the results on here at the time...Do a search, they're in there...Weights are after conversion..The Shindaiwa 34 had the most power and has no oil in the case, can be mounted inverted..
