convert this ! question?
Old 04-17-2006 | 12:10 PM
vasek's Avatar
Default convert this ! question?
hi all,
i am new to gas engines & conversions
what would i need to convert this? how much would it cost?
http://www.duropower.com/item.asp?PID=86&FID=3&level=1
thanks
Old 04-17-2006 | 03:28 PM
Default RE: convert this ! question?
Minimal cost is for a prop hub and muffler, which would be approximately $40- $45 assuming you do the work.
Bill
Oops, forgot the mounting but I would mount to the recoil starter.
The maximum torque/power RPM numbers suggest mild port timing. But a 52cc engine for $125 seems like a deal.
Old 04-17-2006 | 05:23 PM
I got it for $94 shipped.
Ken
Old 04-17-2006 | 08:47 PM
box car: How do you like that 51cc engine so far. Is it good quality? Thanks Capt,n
Old 04-18-2006 | 01:01 AM
vasek's Avatar
Ken, do you have some pics of the conversion & the install?
Bill, you say it's a mild timming would it be enough for a kit that specs 50 to 75 cc gas engine? would there be a better suited engine in this lineup? http://www.duropower.com/index.asp?FID=3&level=1
this would be my first gasser, so i need all the healp i can get.
thanks guys!
V.
Old 04-18-2006 | 06:20 AM
Have not recieved the 52 yet, when i do will post pictures. Have the 32 when my prop hub get here will test and post.
Ken
Old 04-18-2006 | 11:40 AM
I probably would not recommend any engine at the bottom of the specification range, glow or gas. Not all same size engines are created equal.
There is simply not enough known about the engine in question to speculate about it’s ultimate performance. In addition you probably shouldn’t be messing with port timing on a first conversion.
Bill
