Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
 building on a budget-best bang for the buck >
Old 05-07-2006 | 09:45 PM
Mitty's Avatar
Default building on a budget-best bang for the buck
Good evening you finest folks out there.
I have a question.
I want to build a gas/glow trainer for our club to train a young pilots who just gets in the hobby.I think i will go with something as simple as spad with maybe flat bottom foam wings or such. I want it to be a big plane so it will be easily seen @ 3-5 mistakes high.Therefore i will have to use a gas motor.I looked in to conversions a couple years back(for my own plane) but then i had other priorities in my life.Now i am back to conversions and i want to build one as cheap as possible.I already have a weedeater i will donate towards the project .
I wanted to ask you guys who's out there doing a best deal on the adapter and velocity stack?I want to use a glow+gas mix so i won't have to have an EI.Please advice on where to go for the best bang for the buck
Thankfull Mitty
Old 05-07-2006 | 09:49 PM
Bob Laine's Avatar
My Feedback: (91)
Default RE: building on a budget-best bang for the buck
Glo plus gas? I also want to know what that is.
Old 05-08-2006 | 05:27 AM
Mitty's Avatar
http://www.rcuniverse.com/forum/m_12...page_25/tm.htm
Old 05-08-2006 | 09:00 AM
Simple...a engine that will run on a glow/gas mix. Or you could have a twin puller pusher plane with a glow and a gas engine. If one quits the oher engine will get you back to the field. HA!!!!!
Old 05-08-2006 | 09:15 AM
Bob Laine's Avatar
My Feedback: (91)
O K
Old 05-08-2006 | 11:48 AM
or to the crash site.
Bill
Old 05-09-2006 | 02:46 AM
Mitty, If you are not familar with spadword and their Biguns (Large Scale Spads) check them out.
http://spadworld.net/forum/viewtopic.php?t=9321 is a trainer with Echo power. Mine flys like a trainer at 12#. with a CH Ign.
For my glow gas engine experiments, CH Ign http://www.ch-ignitions.com/ supplied the glow adapter. Discovered upon reciept that they did not fit properly in the heads; No problems with CH service; they had some replacements Express / Priority Delivered to friends who hand delivered South of Border. Super service as usual. THANKS.
I tried to make som plug adapter with only limited sucess, the wall thickness is thin. Clearance is minimal. Not worth the time for me to try an make more.
