a mystery of a ryobi that won's start
OH
RE: a mystery of a ryobi that won's start
Rcpilet GREAT POST!
I was wondering if there is a "baseline" needle setting? In the unfortunate event that someone has no clue were to start.
ORIGINAL: RCBOZO
Rcpilet GREAT POST!
Rcpilet GREAT POST!
At idle I set the low needle to maximum RPM. Then I set the Hi needle to maximum RPM less just a touch. Then go over both again. A tachometer is connected during the entire process. My method may not work for everyone.
Bill
ORIGINAL: BillS
I always start at 1 1/2 turns out on both needles on any pumper carb.
Bill
ORIGINAL: RCBOZO
Rcpilet GREAT POST!
Rcpilet GREAT POST!
Bill
NY
I'm glad that we are talking about baseline carb settings for dummies. I was setting up my working Ryobi this weekend and found it somewhat difficult to tune it. I came across the following settings:
High out 1 5/8ths and low out 2 full turns. My high speed tach was about 7100 and my idle speed was about 2000. The response from low to high was immediate.
I assume those numbers are within range for a twin ring ryobi turning a Master Airscrew 18x8 Classic prop at sea level.
I find it difficult to tune these engines because:
1)My tach (which I know is working based upon the "point it at a indoor light" test) jumps around so I end up averaging it;
2)The tach readings seem different from the front (i know-never measure from the front) vs. the back of the engine or if I aim it at the tips or prop hub;
3)Lastly, I refuse to turn the needles while the engine is running. This really makes the procedure difficult, but I can only imagine how hard it would be to do my job if I lost a finger while tinkering my model airplane. I am trying to figure out a safe way to tune the engine while it is running.
NY
Another opinion I use nothing but prem. in my chain saws and 4 wheeler. I can't see much power on lantern fuel . Years ago (AND IM DATING MYSELF) white gas from Ameco was 103 octane
#31
Bill
#32
To make it a lot more easy to adjust carburator Hi and Low screws....take them out and solder a allen head too each adjusting screw. To get a allen head just use your dremal cut off wheel on a allen bolt. When done, you can adjust mixture real easy eith a long "ball" driver for allen screws. Done this years ago. A 20 inch small dia tube with a "Tee" handle works great too. Just solder a cut off allen wrench to steel tube. Gppd luck Capt,n
#33
NY
That allen head trick has to be one of the best ideas yet - Thanks!
Having a "sticky" thread with safety tips would be a welcome addition. Like Norm Abram always says on the New Yankee Workshop, "Before we use any power tools, let's talk about shop safety".
SB
SB
#34
The adjusting tool I made with the TEE handle is really good for fine tunning. With a screw driver...its hard to tell if you got a 1/8 th turn or closer to a 1/4 turn. With TEE handle you can tell by looking at position of handle and see right where you are at. No guessing. Nice. Capt,n
#35
Go to www.zamacarb.com. Click on Service/Aftermarket on the left side. Download the appropriate technical guide. It has all you need to know about rebuilding their carbs including pictures.
Good luck.
Good luck.
#36
AZ
I bought a new Brillelli. The thing acted just like your Rhyobi. I could have swarn it was a fuel problem. Scott even sent me a new carb. to try. In desperation I put in an old spark plug that I had in my tool case for several years. The engine started right up and ran like a champ. That brand new spark plug was the problem. Go figure!
