Carburetor Size? Measure where?
Old 06-28-2006 | 04:39 PM
Default Carburetor Size? Measure where?
I've got a Zama carb off a blower. It measures 13mm on the intake port side and on the outboard side it starts at 16mm where the choke butterfly seats and narrows to 9mm about a fourth of the way into the carb block.
Which is the correct place to measure for determining the carb's size?
Thanks.
Old 06-28-2006 | 04:42 PM
Default RE: Carburetor Size? Measure where?
I'd go with the smallest diameter.
Dr.1
Old 06-28-2006 | 06:13 PM
My Feedback: (29)
Me0,
The size of the carb determined by the diameter of the venturi. In this case this is the 9mm section. Walbro's have a number in 64ths cast into the inlet side and Zama's don't.
Dave
