First Saw conversion
Old 09-06-2006 | 05:31 PM
Default First Saw conversion
First Homelite saw conversion. A Homelite 180 Classic. The saw was give to me and it appears to be very low use. The air cleaner is not even dirty and has never been out. Bar and chain still like new. The piston is shinny new. Compression real good. I have the same prop that I ran on my 25cc Homelite on it (apc 16x8) and it far out-revs the other engines I have used that prop on. It must have reed valves, the carb is near the bottom. I got to get a tack on it!!! So far just running it with stock ignition. Except for a 4 min run on glow/gas and glow plug. It ran real good on that mix too....but I ran out of that fuel. More later. Capt,n
