Ryobi mount
Old 01-30-2007 | 12:16 PM
Antique's Avatar
Default Ryobi mount
Help....I broke a plastic Ryobi mount while testing (don't ask)
Where can I get one ?
Old 01-30-2007 | 12:37 PM
Default RE: Ryobi mount
Is it for a 31cc engine? UPDATE...I may have one...if it fits on back of engine. its just a backplate that also holds carb. I got to go now. Be back later. Capt,n
Old 01-30-2007 | 12:43 PM
My Feedback: (29)
Hi Ralph,
Here is the address of Paragon who made the square plastic mount and a link to the website describing the conversion process. JAG also makes a nice aluminum cup mount as well.
Dave
Paragon Aeronatics 3498 S Dodge Blvd Suite 110 Tucson AZ 85713 520-571-8880 Fax 571-8861
http://www.geocities.com/CapeCanaver...1071/ryobi.htm
Old 01-30-2007 | 02:32 PM
Is Paragon still in business there website is down??
That plastic mount looks interesting.
Old 01-30-2007 | 06:06 PM
Antique's Avatar
The owner passed away, don't know if someone else took over...
Old 01-30-2007 | 07:33 PM
Is this the mount? Looks easy to make? Capt,n
Old 01-30-2007 | 07:57 PM
My Feedback: (29)
Dale,
It would break away in acrash as Ralph found out. I have a JAG round cup mount. It is heavier, but much stronger. Plastic should be cheaper if in quantity production.
Dave
Old 01-30-2007 | 08:03 PM
Would it be possible to make one from sheet aluminum? Like in post #6. Capt,n
Old 01-30-2007 | 08:36 PM
KenLambert's Avatar
My Feedback: (107)
I have some left from when I was cnc machining them and even have some of the carb spacers left.
ID:	610355   Click image for larger version
Old 01-30-2007 | 08:39 PM
Ken: Very nice...thats the way to go folks!!!! Capt,n
Old 01-31-2007 | 08:11 PM
Rcpilot's Avatar
My Feedback: (78)
Has anyone ever made a flat plate mount for the front of the case?
There are a few bolts up front where a guy could mount a flat plate on the engine. It would shorten the engine up a lot when it came to final mounting length.
Old 01-31-2007 | 08:29 PM
Rcpilet: Sounds like a good idea....real neat with electonic ignition or Glow/gas with front mount. Capt,n
