Ryobi 4 cycle RF interferrence
Old 02-05-2007 | 12:32 PM
My Feedback: (29)
Default Ryobi 4 cycle RF interferrence
Hello everybody,
I haven't flown my 26cc Ryobi 4C yet. Too many engines, too little time. I would like to know if any Ryobi four cycle flyers have had any issues with radio interferrence. Reports of problem free use are great also. The engine uses a special 10mm threaded spark plug and I don't know if it is a resister plug or not. I don't think any other plug will fit this engine. Well, now it's your turn to help the rest of us out.
Thanks, Dave
Old 02-05-2007 | 03:01 PM
av8tor1977's Avatar
Default RE: Ryobi 4 cycle RF interferrence
There's a special resistor, shielded, spark plug cap/connector that you can use if you encounter a problem.
AV8TOR
Old 02-05-2007 | 03:41 PM
Sr-Telemaster's Avatar
If you have a ohm meter you can check it by testing from the top to the center electrode. non resistor will show dead short, resistor plug will show resistance.
Old 02-05-2007 | 08:03 PM
Antique's Avatar
If there's an "r" in the number it's a resistor... Look at www.sparkplugs.com
Champion RZ7C
NGK CMR 6 and/or 7
There's a Denso plug also, the porcelain is longer...
Old 02-07-2007 | 04:18 PM
My Feedback: (29)
Hello,
I measured a brand new plug and got 7 meg ohms on the nano semans scale. Most meters won't go that high. I guess that should be enough resistance. A regular meter showed an open cirruit.
Dave
