i need help to set up of carburator
i have a 33cc engine with zama carburator.
i have some questions.
the carburator has 2 tubings , i need conect boot?? what is the inlet gass??
i connect on the smal tubing at the tank, and dont load the gass , i need up the tank to aliment gass to the carburator.
sorry for my bad english , i speak spanish
DC
RE: i need help to set up of carburator
The small tube is used with a remote primer bulb...the bulb has a one way valve in it..If you don't use the bulb you should plug the small tube, the engine won't run with it open...
hi rcign1
the samll tube is conect to carter of engin?? or where??? i can tap on the carter of engine and plug one tubing with one way valve,
and the fat tubing to the tank of gas???
the tank of gas is open on one line tho the athmosfere??
Plug the small one-gas tank line is the big one. Where did you get the ignition system/prop hub for this motor?
Run a three line tank-Fill, Vent and Carb line.
