poulan 31cc rear intake rear exhaust?
My Feedback: (14)
I was in WalMart and saw a Poulan 31cc weedeater PPB100 for $89.00. Has anyone else seen or have experience converting this engine?
VA
RE: poulan 31cc rear intake rear exhaust?
I am familiar with this engine. It was also branded Craftsman. The older ones had spring mounted mufflers, but the newer ones have bolt mounted mufflers. It has a reed valve and plastic rear cover. It also has dual rings. Should be a geat fit for a plane with a narrow cowl. The crankshaft extends quite a bit past the front of the engine. There is quite a bit of cutting to do also. I never fully converted mine and/or ran it because I didn't like the spring muffler.
My Feedback: (14)
If this is the Ryobi engine is it a good engine and can it be found anywhere for less?
Do you think it could spin a 18X8 at over 7500 rpm?
