Need an opinion for custom prop hub
Hello everyone.
I would like to ask if it is relatively safe - and doable - to make a prop hub out of bronze/brass that takes place of the 10mm flywheel nut on a GX25. At least brass is stronger than aluminium, though heavier...
I'm maintaining the engine fully stock as possible (no cutting or grinding) as it's going to be placed on a hovercraft, and if need be, later on it can be returned to it's stock form with cowl, etc, for another application.
Thank you
Thank you
RE: Need an opinion for custom prop hub
Thanks.
I asked this because my machinist has mainly larger OD pieces in brass than in aluminium.
Cheers!
Cheers!
