Ryobi Powered Hovercraft
Old 04-18-2007 | 05:26 PM
stgrlee's Avatar
Default Ryobi Powered Hovercraft
I have two converted Ryobi engines and have always wanted to build a hovercraft. Anyone have an idea as to how big, and heavy it could be? I would like to use both engines, one for lift and the other for propusion. Anybody seen any plans any where?
Old 04-18-2007 | 06:48 PM
Antique's Avatar
Default RE: Ryobi Powered Hovercraft
MANY years ago you could buy plans for a hovercraft from Herb Bartlett in Arizona...
Might be worth a search....
I don't think a Ryobi powered hovercraft would be able to get off the ground..
Old 04-19-2007 | 06:43 AM
It can get off the ground.
You need to make an estimate of the final weight of the craft, say, 3~4 times 1 engine weight for a rough estimate.
The you will have to calculate the area of the hull that gives you a small pressure (weight per square area unit) - better ask this on the hovercraft forum.
For the lifter engine, use a 4 blade prop. If you use for example, a 14x6 2-bladed prop for normal running, use a 12x7~12x8 (or 11x8 for more rpm). Multi-bladed props are great for making pressure - that's what you need for the lift, a compressor-like engine.
Good luck!
Old 04-19-2007 | 11:22 AM
My Feedback: (29)
stgrlee,
You may want to run them on gas/glow to save weight. This would save a pound for each engine. The typical mag ignition Ryobi weighs about four pounds.
Dave
